Classifieds » Engines, Accessories and other Mechanicals » Wrecking 4agTe and Other stuffs (Pics added of sum things)
Gr33nM0nk3y
Wrecking 4agTe and Other stuffs (Pics added of sum things) Tue, 05 October 2004 13:21 Go to next message
Hey guys, due to the fact i suck and have no more money to finish him, my black ke70 with the 4agte is going to be split.
If you want pics i can email them to you, im not sure how to post pics, ill search for info on how and try. but for now, ask and i shall send... well try to send Smile
Prices are neg to an extent, ie: if ive something for 400$ please dont pm me saying ill give you 200$ and i have to pay for freight to the eastern states haha thanks Smile ..all constructive critisism noted, all smart ass ones ignored.
heres the list of my stuffs:
1 x Big Port Blue top head NO Cams - SOLD
1 x Small port gze head WITH cams (the model that came out in 1992ish era- $150 (has been skimmed flat, never run the mtr after the head was skimmed)
1 x Pair of blue top Big port Cams - $100
1 x FWD 100kw SMALL port manifold Reversed for RWD Application - $150,
I'm yet to clean up the welds on this yet so looks sh*t, will clean up and get some pics ASAP, I'm kinda busy so it may take till sat. Yes i want to sell it.. but be patient.
1 x 8 Bolt Flywheel. Would have to be close to brand new, came out of a wreck at Just toyota with around 30,000km/s Ive never had the pleasure of using it. Cost 400.. and then I had it faced/machined - $300
1 x SR20DET Fuel Pump, Don't know the actual specs, use google, i was told good for around 180kw's?? Don't quote me thou. Came out of a 70,000km wreck - $70
1 x 4agze Starter motor - $40 -sold
1 x 1g-gte Intercooler (One ali bracket on cooler broken off) - $100
I have the water pump also, not sure what condition this is in, ill check ASAP if anyone is interested then ill put a price on him.
1 x Gze airflow meter, will get numbers of it if anyone is interested.. Flap type.. Looks very restrictive, worth going aftermarket ecu just to avoid this brick. - $80
1 x Gze standard ECU, same deal as airflow meter as in i will get numbers etc if anyone is interested. - $120
4 x Standard Gze Injectors - $100
WILL SELL THIS AS A "KIT" ONLY. Please dont ask If I will seperate.. If i get desperate and choose to ill do a new post with prices for each item.
1 x CT26 Turbo, Steel wheeled of 7m supra. If any then very very very little / No shaft play, Has intake pipe bit machined out for larger air flow, I can measure if ppl need to know.
1 x Custom VERY high mount manifold. Be aware, You will need to cut your bonnet for a very tough look.. trust me.. People will phear your car. (Note, this may not be legal in your state.. so a nice little bonnet scoop will sort this.) turbo sticks out about 3cm's. Kinda the only way to fit this turbo in Smile Just finishing off manifold now, Pics up by Sat at the latest.
1 x Braided steel line with Copper fittings for oil supply from block to ct26
1 x Steel/High temp hose Return line
1 x 3inch Dump.. thick and heavy Smile comes with exhaust sensor "hole" (has bolt holes to bolt it in etc)
1 x 1 Wire Exhaust Sensor (brand new)
Can also throw in Gze (any diff to G-e?) sump with a pipe for the return to connect to.
Can also throw in 3 inch Side pipe (connects to dump, No Cat, Just a straight pipe that goes to about 3/4 under the front door then angles out to the outside of the car.. its not pretty. but it does the job.
asking $850 for the "kit" THIS PRICE IS NOT NEG. PLEASE DONT OFFER A PRICE. I AM FIRM AT THIS PRICE. thanks.
if you want to split it after you buy it then go ahead.
1 x Motorcycle Fuel Filler cap with 2 keys, cost 180 after i had to get the keys cut (30$ for keys!!! argh) - 100 (comes with some ke70 skin to weld it on)
1 x Ke70 Shell - No motor No Box No suspension No back doors No Bonnet No Front grill No bumpers No Fuel Filler area (it's a hole) Half a floor Bend Chassis Rails No Boot Lid
Damn I should be paying YOU to take this hahahaha I think Ill call Sims metal for that Razz Unless anyone wants a paperweight then come take it
2 x AE71 Cross members (For fitting a 4ag(z)e to a ke70 - $75ea
1 x Hydraulic Clutch cylinder with steel line that runs to box. - $50
2 (1 x LHS, 1 x RHS) x 4a-c (To fit 4ag(z) to X-Member)) Engine mounts, Rubber in excellent Condition - $40each
If I think of anything more Ill get the info up....
Thanks. Once again, Please no retarded comments / Stupid offers.
Sad to see it all go.
Oh Im in PERTH. If you think it's gonna be heavy then dont expect it to be post friendly. ie: It'll be expensive.. Esp. the turbo kit. Will weigh it when i get a chance.
-bc
[Updated on: Fri, 22 October 2004 03:26]
Adsport
Perth WA
Re: Wrecking 4agTe and Other stuffs Tue, 05 October 2004 13:35 Go to previous messageGo to next message
if you want to see how angry this car looked with the kit check out hot 4's mag #109 may of 2004 (yellow s2000's)and fast fours from the same month (motorvation specials), its on the front cover.
cant beleive i put that thing together, and it will never live, money sux!
chrisellis
Re: Wrecking 4agTe and Other stuffs Tue, 05 October 2004 14:20 Go to previous messageGo to next message
might be interested in a couple of these itmes man, pending how consistant my work is.
Also to answer a couple of ur question marks;
the gze starter motor is the same as a 4age, and to make it worse a 4a-c, i know cause im currently using one in my gze (probly makes it go slower though, lol). So u might wanna ajust the price of that, or maby someones after a genuine gze item and will pay for that.
The sumps are different on ge and gze, i think the gze has no return, so ppl tend to replace these with ge items for an oil cooler etc?? anyone else care to comment.
Its so temping seeing that conversion gear for sale man, like i said pending cash flow ill be in contact. Chris
eurospec86
Barbados
please email me pics of the big port head( is it only missin cams? how many miles on it?) aswell as gze ingectors and sr20 fuel pump thanks jaf86er@yahoo.com
Gr33nM0nk3y
Re: Wrecking 4agTe and Other stuffs Tue, 05 October 2004 14:39 Go to previous messageGo to next message
Hey chris, Thanks for the info on the starter motor, Im not sure what a normal price on a starter motor is, but guessing you could grab a 4a-c starter for stuff all in the local paper haha Ill adjust my price to say.. 40? or offers?? if anyones keen.
Let me know if your keen on the other stuff when you know, might have a few things floating around if other stuff has gone.
eurospec86 - Just sold the bigport head to a mate (Sorry) ill send you a pic of the injectors and the fuel pump tomorrow nite around this time. ta
Gr33nM0nk3y
Re: Wrecking 4agTe and Other stuffs Wed, 06 October 2004 12:17 Go to previous messageGo to next message
sorry euro, borrowed my bro's camera, took photo's of all the gear, and i think i just broke his camera *pissed off*
Ill get pics to you tomorrow.. sorry for the fk around mate.
Re: Wrecking 4agTe and Other stuffs Fri, 08 October 2004 04:39 Go to previous messageGo to next message
4AGZE Idle Speed Control Valve? (I think its attached to the throttle body)
Gr33nM0nk3y
Re: Wrecking 4agTe and Other stuffs Sun, 10 October 2004 05:41 Go to previous messageGo to next message
nah sorry dude, i gave the whole charger/throttle body/pipes/cooler away to a mates dad when i 1st got he mtr.
To anyone thats interested, havent been able to get photo's up yet, had a motorbike accident on friday morning, ph4rked my hands up so im having an opp on monday morning to hopefully fix em, ill try and sort pics out when im better, mite see if my bro can put sum up. cheers for patients guys.
ill even post pics of my bike and hands so doesnt look like im just making excuses haha poor bike.
laters
Gr33nM0nk3y
Re: Wrecking 4agTe and Other stuffs Fri, 22 October 2004 03:06 Go to previous message
i have a few pics up, didnt manage to get everything shot thou.
http://www.pbase.com/gr33nm0nk3y/inbox
Previous Topic:stock 20v ecu and air flow meter
Next Topic:2T+T50=$300 ono
Current Time: Thu Oct 22 22:02:32 UTC 2026
Total time taken to generate the page: 0.0066530704498291 seconds
