Toymods » Tech & Conversions » Quick Q: 2T/2T-G Distributors
SeptemberSquallIndustries
Quick Q: 2T/2T-G Distributors Tue, 05 October 2004 13:49 Go to next message
Can a 2T distributor be used in a 2T-G without modifications?
Thanks in advance.
pheonix83
Devonport Tasmania
Re: Quick Q: 2T/2T-G Distributors Tue, 05 October 2004 22:16 Go to previous messageGo to next message
yes
EMP-2TG
Carlingford, Sydney
Re: Quick Q: 2T/2T-G Distributors Tue, 05 October 2004 23:32 Go to previous messageGo to next message
but there not the same
pheonix83
Devonport Tasmania
Re: Quick Q: 2T/2T-G Distributors Wed, 06 October 2004 00:43 Go to previous messageGo to next message
since when ?
same block, same oil pump type.
same gear drive, 4 cylinders, points ?
you can use an electronic dizzy in a 2t, so why not a points 2t dizzy in a 2tg ?
early 2tg's were the same points dizzy anyway werent they
thetoyman75
Club President
Re: Quick Q: 2T/2T-G Distributors Thu, 07 October 2004 08:18 Go to previous messageGo to next message
The Dizzy's are NOT the same.
You CANNOT use a 2T dizzy in a Carby 2TG, might get away with in in an EFI one but probably not. The fine adjustent dial fouls on the manifold preventing the correct timing adjustment/orientation of the dizzy. A 2TG dizzy does not have this dial and the shaft lengths are different to allow clearance.
So the short answer is NO it won't fit !
greenta22
Dandenong Ranges, VIC
Re: Quick Q: 2T/2T-G Distributors Thu, 07 October 2004 12:08 Go to previous messageGo to next message
ive got a complete 2T unit and only a bare housing on a shaft with the cam on my 2TG one. can you transfer the 2T dizzy internals (weights, springs, points etc.) into a 2TG dizzy housing? im assuming you can, seeing as they are the same size in the critical dimentions.
[Updated on: Thu, 07 October 2004 12:09]
thetoyman75
Club President
icon12.gif  Re: Quick Q: 2T/2T-G Distributors Thu, 07 October 2004 23:11 Go to previous message
Nice avatar Wink I haven't seen that engine for a while !
Not sure on swapping the internal. I can't see any real reason why it shouldn't work altho the weights and dizzy graph in a 2T will be different to a 2TG one due to the different Cam/reving characteristics. So you will need to have it regraphed Smile
Previous Topic:Holley Vs Carter Fuel pumps
Next Topic:ST185 Starting Problem
Current Time: Sun Oct 25 00:40:30 UTC 2026
Total time taken to generate the page: 0.0057899951934814 seconds
