Toymods » Tech & Conversions » Which Mounts? 1j onto mx83 c/member.
manmx83
icon5.gif  Which Mounts? 1j onto mx83 c/member. Tue, 05 October 2004 14:37 Go to next message
G'Day the Forum.Can someone tell me which engine mount to use 1j from jza70 onto stock cressi c/member.Thanks.Pete.
jasonp1977
Re: Which Mounts? 1j onto mx83 c/member. Tue, 05 October 2004 23:05 Go to previous messageGo to next message
what year cressida?
The crossmember changed in the facelift to be the same as the JZX81 crossmember.
Re: Which Mounts? 1j onto mx83 c/member. Wed, 06 October 2004 00:32 Go to previous messageGo to next message
89/90 MX83 you will need to use the JZA61 mounts (I'm pretty sure they will fit, BlackSupra has the details of where to get them), or source a 91/92 Crossmember
91/92 MX83 you will have no worries.
manmx83
Re: Which Mounts? 1j onto mx83 c/member. Wed, 06 October 2004 11:02 Go to previous messageGo to next message
Thanks Guys,So I have A 92 and I am Sweet? I have had so much luck with this conversion! So which mount do I get to replace the broken 1j mount? [ I am wrapped because I sorted the ABS conversion today,Same 32 teeth on sensor jza70 and 92 mx83 cressida so my ABS is a goer] Yeah,so do I buy cressida mounts or JZA70 mounts? Cheers.Pete.
jasonp1977
Re: Which Mounts? 1j onto mx83 c/member. Wed, 06 October 2004 11:15 Go to previous messageGo to next message
I'm not sure if you can use the jza mounts, I'm using JZX81 brackets and mounts on mine.
part numbers for JZX81:
rubber mounts is 12360-46010
LH engine mount bracket 12315-46030
RH engine mount bracket 12311-46020
for JZA70:
rubber mounts is 12361-46040
LH engine mount bracket 12315-88400
RH engine mount bracket 12311-88400
manmx83
Re: Which Mounts? 1j onto mx83 c/member. Wed, 06 October 2004 13:56 Go to previous message
Thanks Jason,I guess it will all become clear when I drop it in but would like to be in the know beforehand.It has been pissing me off working on this engine/gearbox without a manual.I like to read the instructions before getting the tools out.
Took me a while today to sort out how to detach the clutch fork on r154 to allow removal.........So Simple once you know.
Laughing Cheers.Pete.
Previous Topic:car goes "duga-duga-duga-dug"
Next Topic:1GGTE AFM
Current Time: Sun Nov 1 13:22:48 UTC 2026
Total time taken to generate the page: 0.0047290325164795 seconds
