Classifieds » Miscellaneous » Wrecking: Camry sv11
Duff
Wrecking: Camry sv11 Fri, 27 September 2002 11:28 Go to next message
Wrecking toyota camry sv11 1984.
Front damage only.
Engine ok. (2se)
other parts available.
Located in Adelaide.
[mikey]
Re: Wrecking: Camry sv11 Sat, 28 September 2002 11:10 Go to previous messageGo to next message
Do you have the 5-stud rear bearing carriers, not the whole hub. Id be interested in just these 2 parts.
Michael
Duff
Re: Wrecking: Camry sv11 Wed, 02 October 2002 08:29 Go to previous messageGo to next message
[mikey
wrote on Sat, 28 September 2002 21:10]Do you have the 5-stud rear bearing carriers, not the whole hub. Id be interested in just these 2 parts.
Michael
I think so but i dont know what a "5-stud rear bearing carriers" is or what it look like, please explain.
wagonist
Toymods Club Treasurer
Re: Wrecking: Camry sv11 Thu, 03 October 2002 01:14 Go to previous messageGo to next message
Do you rear drum brakes or discs?
I recently changed my rear drums to discs & have the whole rear drum assembly sitting around waiting to be chucked. They're yours if you pick them up.
[mikey]
Re: Wrecking: Camry sv11 Thu, 03 October 2002 22:09 Go to previous messageGo to next message
wagonist,
yours is FWD isnt it?
I just need the bearing carrier and spindle, it bolts onto the hub through 4 bolts usually and the disc or drum sit on it!
michael
wagonist
Re: Wrecking: Camry sv11 Thu, 03 October 2002 22:20 Go to previous message
Yes, my car is FWD, and it has the same parts as the Camry & Celica.
The outer part where the drum or disc sits is shaped slightly differently depending on which you're using.
I was only going to throw mine out anyway. They're from a 1996 model so the bearings should still be ok & they haven't been on the car for at least 6 months.
Previous Topic:KE70+AE71 panels
Next Topic:SOARER mz20discs/calipers
Current Time: Thu Oct 22 14:51:21 UTC 2026
Total time taken to generate the page: 0.006126880645752 seconds
