Toymods » Tech & Conversions » 20v Fault diagnosis
PerformanceCars
20v Fault diagnosis Tue, 05 October 2004 23:37 Go to next message
My 20v seems to have gone into "limp" mode.
I have "W" pin 8 on the small plug connected to my engine light - which turns on when the ignition is ON.
nothing changes when i ground TE1 - just constant engine light.. Sad Shouldnt this be flashing any fault codes to me?
any suggestions.?
PerformanceCars
Re: 20v Fault diagnosis Wed, 06 October 2004 06:15 Go to previous messageGo to next message
No One ?? Sad Sad Plz..
EvilJack
Sutho/Hills NSW
Re: 20v Fault diagnosis Wed, 06 October 2004 06:19 Go to previous messageGo to next message
http://www.club4ag.com/faq%20and%20tech_pages/ECU% 20Diagnostic%20Codes.htm
Have you seen this?
may help your steps Cool
PerformanceCars
Re: 20v Fault diagnosis Wed, 06 October 2004 06:57 Go to previous messageGo to next message
Yeah ive seen the list of fault codes etc.. I just cant get the check light to give me the codes.. it just stays on all the time.
ive even opened the ecu and checked i have the correct wires..
its got me a bit confused..
Confused
sideshow
Re: 20v Fault diagnosis Wed, 06 October 2004 08:11 Go to previous messageGo to next message
if light stays on all the time then ecu might be faulty
if theres nothin wrong u should still get constant flashing
u need to join e1 and te1
even try removing throttle or air flow sensor plugs
create an error and see if the ecu picks it up
then u can see if the warning light is workin ok
i have come across some faulty ecus
was it just wired up recently or has it been running fine for awhile
did u recently jump start it?
[Updated on: Wed, 06 October 2004 08:12]
PerformanceCars
Re: 20v Fault diagnosis Wed, 06 October 2004 10:14 Go to previous messageGo to next message
has been running faultless for 2 years.
No jump starts lately - problem started while driving normally..
Should the check light only turn on when the key is in ON position? because this one turns on when the key is on ACC.
sideshow
Re: 20v Fault diagnosis Wed, 06 October 2004 14:17 Go to previous messageGo to next message
well the 20v is wired incorrectly if the ecu light comes on with acc
but this shouldnt cause probs
unless the ecu light is wired to acc and not to ign
PerformanceCars
Re: 20v Fault diagnosis Wed, 06 October 2004 23:48 Go to previous message
why would the ecu light being wired to acc (but still grounded through the ecu) cause a problem?
me and electrics = BAD..
Previous Topic:KE55 offset/studpattern
Next Topic:18RG carbie inlet gasket
Current Time: Sat Oct 31 03:10:15 UTC 2026
Total time taken to generate the page: 0.046658992767334 seconds
