Toymods » Tech & Conversions » pre-loading diffs
Gased
pre-loading diffs Fri, 27 September 2002 14:57 Go to next message
Can anyone explain the principle of preloading diffs?
I've got a T series diff and want to make sure it is in spec before I install it.
Team,
What are the specs - preload torque, play etc and how to measure etc
I've been told the crown/pinion play should be less than 6 thou all round measured with a dial guage. How to preload?
Hope the pic comes out below - showing the loading ring, one of two. I take it that this locates the crown against the pinion. I've heard about using die blue to locate contact area on crown ring.
How much lateral play is allowed in the inner cogs that attach to the axle?
David
P.S any leads as to add a pick - i'm using a Mac
Gased
Re: pre-loading diffs Fri, 27 September 2002 15:06 Go to previous messageGo to next message
Err another attempt at postimg diff pic this time using Netscape
file:///2/Desktop%20Folder/diffcentresml.jpg
5KinKP60
Finland
Re: pre-loading diffs Fri, 27 September 2002 15:35 Go to previous messageGo to next message
The pic has to exist in the net. You just link the path to it, and it gets displayed here on this board.
In other words, if the pic is in your computer, it cannot be linked here.
You'd have to figure out how to set it up at your web providers server, then just link it to this forum.
I can do that for you, send the pic to me at:
artsi_fi@yahoo.com
-Artsi
5KinKP60
Finland
Re: pre-loading diffs Fri, 27 September 2002 15:57 Go to previous messageGo to next message
I have had found a good site on this issue long time ago. Just remembered I have it in my bookmarks. Here you are:
http://212.21.193.192/svcman/sm03a.html#DIFFERENTI ALBEARING
It's american site, dealing with american diffs but all info is applicaple to Toyota. It has very good info, and pics to go with them too.
http://212.21.193.192/svcman/image/0310.jpg
http://212.21.193.192/svcman/image/0330.jpg
http://212.21.193.192/svcman/image/0331.jpg
http://212.21.193.192/svcman/image/0332.jpg
Here is a shot of real life appearance:
http://www.geocities.com/lars915/Images/d44_pattern.jpg
site addy: http://www.geocities.com/lars915/gears.htm
-Artsi
Gased
Re: pre-loading diffs Sat, 28 September 2002 08:22 Go to previous messageGo to next message
Artsi,
way cool, thanks man. Just looked at the first URL it looks good.
The bolts on my crown wheel have these brackets under them that have tags folded up apparently to stop the bolt from turning?
Is it possible to repace the seal oneself or is this best left to a an expert?
BTW I found the image doesn't have to be on the web! Just the javascript to inset the image tag doesn't work with IE5.1 on Mac. Netscape works. I think you can just type the image tag into the message giving a path to the image. The http ref that pops up using the button can be replaced with the file tag and path to image on your computer.
Thanks again for the post, a picture is worth a thousand words.
David
Hunty
Re: pre-loading diffs Sat, 28 September 2002 09:44 Go to previous messageGo to next message
Pretty sure the image has to be online..otherwise toymods would be gettin hell pics uploaded to it
Gased
Re: pre-loading diffs Sat, 28 September 2002 12:28 Go to previous messageGo to next message
Hunty,
Nah, the pic I posted was definitely not uploaded to any web site.
David
Youngy
Eskilstuna, Sweden
Re: pre-loading diffs Sat, 28 September 2002 14:52 Go to previous messageGo to next message
Have you tried to view the picture from another computer other than your own? Probably not as all I and I say everyone else get is a broken link as the link is referring to a directory that no one else can get to ie your computer.
The picture has to be online somewhere in the world for the rest of us to see it. Or you could expose your own computer to the rest of the world - ie become a webserver in effect. But you might not like to do that.
Have fun
Gased
Re: pre-loading diffs Sun, 29 September 2002 10:27 Go to previous message
Bugger,
your right, looked at the source code - and there I was thinking that it was like an attach/upload function Embarassed Makes posting pics quite an effort. But I can see how the forum admins would want it this way else the disk space on the server would get chewed up. Bout time I got my site together.
D
Previous Topic:3SGTE rebuild on its way!
Next Topic:ae82 front bar on ae86 sprinter
Current Time: Mon Oct 26 15:58:17 UTC 2026
Total time taken to generate the page: 0.031943082809448 seconds
