Toymods » Tech & Conversions » Electrical? 3SGTE problem, who knows there stuff?
Aust162
Melb, Victoria
Electrical? 3SGTE problem, who knows there stuff? Wed, 06 October 2004 06:38 Go to next message
Hey guys, i REALLY need some help with the weird problem i'm having.
during the daytime my car runs perfectly!however when i turn my headlights or parker lights on the car hits boost cut!i've tested this during the day too. i cant boost the car hard or put my foot down quickly when my lights are on! I'm running about 12psi and i have a fcd installed.it has boost cut as low as 6psi and 13psi.
do u think something has gone wrong with my wiring soon my car has had the swap?it didn't have this problem in the beginning.
the car is throwing code's 34,35.
where should i start looking at with this problem?? any ideas would be greatly appreciated.if u need any more details just ask me! thanks Smile
the car in question is a st162 with a gen2 3sgte (sw20), factory ecu.
Puffy
Re: Electrical? 3SGTE problem, who knows there stuff? Wed, 06 October 2004 13:53 Go to previous messageGo to next message
Aust162 wrote on Wed, 06 October 2004 16:38
You are running 12 pounds but your fuel cut is set to 13psi........ is this correct?
Beej
Re: Electrical? 3SGTE problem, who knows there stuff? Wed, 06 October 2004 15:02 Go to previous messageGo to next message
Aust162 wrote on Wed, 06 October 2004 16:08
what hes saying is he has hit boost cut at those pressures
Puffy
Re: Electrical? 3SGTE problem, who knows there stuff? Thu, 07 October 2004 00:33 Go to previous messageGo to next message
The errors would relate to one of two things:
CODE 35
An open or short in the turbocharging pressure sensor circuit (Check your FCD wiring) or the pressure sensor itself has failed.
CODE 34
I would say check your FCD to make sure everything is fine as if this is not working the extra load from the alternator when your headlights would be causing that extra spike in psi. Considering that fuel cut is 12 to 13psi standard on a GT4 and your receiving a code 34 something tells me your FCD is not doing its job.
Aust162
Melb, Victoria
Re: Electrical? 3SGTE problem, who knows there stuff? Thu, 07 October 2004 02:21 Go to previous message
thanks for ur imput puffy Smile .what gets me though is that the car did this to me twice (both times at night)before i had even put my bleed valve in,disconnected the tvsv and put the fcd in Confused the car has never faulted during the day. from what you've said i think my turbo pressure sensor might be stuffed Sad . anyway my plan now is to remove all the stuff i put in and bring the car back to standard. then i will see how it goes.
thanks again.
Previous Topic:ae82 gearbox alternatives
Next Topic:4AGZE Piston Rings - $$??
Current Time: Tue Oct 27 18:14:45 UTC 2026
Total time taken to generate the page: 0.10669302940369 seconds
