Toymods » Tech & Conversions » Timing Belt woes :(
Dust
Timing Belt woes :( Wed, 06 October 2004 07:28 Go to next message
before takin my timing belt off I marked where it was etc, now I go to check the position and the marks dont seem to be right, how do i check its right :/
Dust
nick2b
Re: Timing Belt woes :( Wed, 06 October 2004 07:29 Go to previous messageGo to next message
On some cars a little chip is cut out so they both line up exact
Dust
Re: Timing Belt woes :( Wed, 06 October 2004 09:29 Go to previous messageGo to next message
sorry not understanding, where is this chip cut?
1ggte btw
Re: Timing Belt woes :( Wed, 06 October 2004 10:14 Go to previous messageGo to next message
1G is easy. Make sure the engine is at TDC, line the notch on the cam gear with the notch behind it. Piece of cake.
leebroozlee
Re: Timing Belt woes :( Wed, 06 October 2004 13:34 Go to previous messageGo to next message
the chip he's talking about is probably on the outer edge of the crank pulley
BLK1GGTE
South Eastern Subs
Re: Timing Belt woes :( Fri, 08 October 2004 10:09 Go to previous messageGo to next message
SO hang on do line up the dot of the cam gears to the notch on the flywheel when its at TDC or with the notch behind the cam gears on top...i need to change my gears and want to make sure..and how can u make sure its at number one cylynder and not 180 degrees of on the 1G...
Re: Timing Belt woes :( Fri, 08 October 2004 10:12 Go to previous messageGo to next message
Yeah, make sure its at TDC. Then line both the cam gear notches with the marking on the bit right behind them.
It is a lot easier to do if you clean that bit off like this: http://iamfrank.ath.cx/xx/images/08072003/images/0 8072003%20002.jpg
BLK1GGTE
South Eastern Subs
Re: Timing Belt woes :( Fri, 08 October 2004 10:15 Go to previous messageGo to next message
Damm my are at the bottom now..the dots on the cam wheels whnt its at TDC...like 180 degrees out..but that can't be right the motor would run then..which it does...or would it
Re: Timing Belt woes :( Fri, 08 October 2004 10:33 Go to previous messageGo to next message
Well....the cams are going to spin how many times for each revolution of each full cycle?
You'll need to turn the engine around one more time.
dingaling
tas
Re: Timing Belt woes :( Sat, 09 October 2004 12:26 Go to previous message
if you want to make sure your not 180 degree's off.
take number 1 spark plug out, get a long straw or something long, put it in the spark plug hole, turn your crank and watch the straw, you'll find TDC without a doubt. Of course that is just a useful trick with cars that seem to lack appropriate markings. (datsun bluebird comes to mind). Still it's a foolproof trick.
Previous Topic:differential shortening and mounts welding - melb?
Next Topic:HELP!!! 2TGEU not firing
Current Time: Wed Oct 21 11:50:07 UTC 2026
Total time taken to generate the page: 0.025846004486084 seconds
