Toymods » Tech & Conversions » Fuel returns??
kidgod
Mackay , AUS
Fuel returns?? Sat, 28 September 2002 01:44 Go to next message
my friend was talking about getting 'fuel returns' he cant find any from what he told me what they look like(cylinder, farily small, three pipes coming off it) it sounds like it would be easy to make i was just wondering if any1 out there knows what they are and if any1 has any spare how much. he said that it cuts fuel consumption by heaps, im a pizza deliver so i am very interested in getting one.
[Updated on: Sat, 28 September 2002 01:46]
Re: Fuel returns?? Sat, 28 September 2002 03:57 Go to previous messageGo to next message
Ummm im confused Confused Are you talking about a surge tank?
kidgod
Mackay , AUS
Re: Fuel returns?? Wed, 02 October 2002 02:52 Go to previous messageGo to next message
i think that it is something like a surge tank but it is small and hooks onto ur fuel lines near ur carby, i never thought about it as a surge tank.
haggis
Re: Fuel returns?? Wed, 02 October 2002 05:20 Go to previous messageGo to next message
The object you describe with '3 pipes' sounds kinda like the mechanical fuel pump from a 4A-C AE82 corolla.
Do you have a picture of the device, or a clear idea on what it's actualy supposed to do?
I've heard of many devices that are supposed to cut fuel consumption, but none have ever come close to haveing the engine properl tuned for economy, and sensible driving.
More info would be a help....
Craig.
Hunty
Re: Fuel returns?? Wed, 02 October 2002 17:40 Go to previous messageGo to next message
I remember today tonight did a story a while back on a device that was designed to use about 30% less fuel when installed. i thought it was pretty dumb coz if your car is properly tuned and u drive it sensibly and you think it still uses to much fuel THEN GET A FREAKIN DAEWOO MATIZ!!!
But yeh it was an inline fuel regulator/restrictor which basically just leaned out the fuel mixture. But on road tests showed they didn't really work. I suspect the ECU in the cars they tested i think it was falcoon, commonwhore and Camry just adjusted everything to suit the leaner fuel.
This probably has nothing to do with what you are talking about but yeh. I don't actually remember what the device looked like so i cant say if it had the 3 pipes
kidgod
Mackay , AUS
Re: Fuel returns?? Thu, 03 October 2002 00:53 Go to previous messageGo to next message
ok i think hunter was on the right track, but if it dosent work why try and find them? if any1 has other ideas on fuel consumption other than tuning please post.
GIN51E
Berowra-Sydney
Re: Fuel returns?? Thu, 03 October 2002 01:15 Go to previous messageGo to next message
only thing i know with 3 pipes and one is a fuel return is a mechanical fuel pump where the un-needed fuel just gets sent back to the tank, there is nothing you can really do to make your car use less fuel, only real option is a tune, make sure the carb settings are all correct, the correct spark plugs and gap size as well as timing advance,
there wouldn't be anything you can just connect to the motor to stop it from using fuel as thats going to reduce power and therefor you will have to push te gas pedal down even more so it won't work out,
i got my car dyno tunned, result was an increase in power and therefor i get an extra 80K's out of a tank.
i think you would have to be dreaming if you think there is a device you can connect into the fuel line to save on fuel.
only way to save fuel is to get the engine running to a point where its making the most power out of every drop of fuel and thats where you save on fuel consumption
dorikin
NE Melbourne
Re: Fuel returns?? Thu, 03 October 2002 03:23 Go to previous messageGo to next message
he's not talking about the charcole canister is he?
haggis
Re: Fuel returns?? Thu, 03 October 2002 05:48 Go to previous message
I'd agree fully with Gin5ie, there is no add on which will reduce fuel consumption. These are all marketing gimiks with no real value. You would be much better off spending the money on getting it running correctly in the first place.
If you follow the steps that Gin5ie suggested, then you should see results. Keeps the car well maintained as well, Change the air and fuel filters when recomended by the manufacturer.
dorkin, from memory the charcole canister has more then three pipes. It also quiet removed from the fuel delivery system (even tho it does have a pipe to the tank) It just catches vapors and the like to reduce polution.
Craig.
Previous Topic:Corolla Seats
Next Topic:79 corona wagon ???
Current Time: Sun Nov 1 11:49:08 UTC 2026
Total time taken to generate the page: 0.0046310424804688 seconds
