Toymods » Tech & Conversions » GZE boost problems
JP_GZE
GZE boost problems Thu, 07 October 2004 02:53 Go to next message
I have a map GZE run by a microtech LT8-s ecu with extactors and a 2 inch exhaust. I installed a boost gauge yesterday but so far have only got a maximum boost reading of around 5psi. The supercharger is in good condition according to the mechanic that did the conversion - I thought these things ran about 8 - 9psi with the stock supercharger pulley.
Can anyone suggest the problem here?
Also, which of the follwing mods would you recommed i do first; upgrade to a bigger exhaust (2.5 inch??), 175mm supercharger pulley, or front mount a larger cooler?
The dyno gave a reading of 115hp at the wheels. Does this seem about right?
feral4mr2
Bundaberg, Qld.
Re: GZE boost problems Thu, 07 October 2004 03:02 Go to previous messageGo to next message
where have you tee'd the boost guage into?
drift86levin
brisvegas
Re: GZE boost problems Thu, 07 October 2004 03:19 Go to previous messageGo to next message
the power sounds about right..i prolly would go for a better inltercooler..the exhaust should be right if its mandrel bent..you can play with the pully if you like..but i would suggest getting a bigport 4age cam in the intake side and some adj cam gears set the cam timing up for 114 deg L/C's..run about 13 deg advanced on the ignition timing..and put a 3SGE throttle body on it..do a search in the forums for '4agze throttle body' i posted up a how to guide on the throttle body..it alone is about 5BHP and a heap more responsive..
JP_GZE
Re: GZE boost problems Thu, 07 October 2004 03:23 Go to previous messageGo to next message
i T'd the boost gauge into the vacuum line running to the microtech
drift86levin
brisvegas
Re: GZE boost problems Thu, 07 October 2004 03:30 Go to previous messageGo to next message
there is a line from the ABV..try plugging it into that one..
crzysx
Re: GZE boost problems Thu, 07 October 2004 08:33 Go to previous messageGo to next message
where abouts is the thread for the swap from the gze throttle body to the 3sge one.
feral4mr2
Bundaberg, Qld.
Re: GZE boost problems Thu, 07 October 2004 10:22 Go to previous messageGo to next message
best place to tee into is normaly the vacum line from the inlet manifold to the brown fuel reg vsv. same one you use when you do the ABV mod.
Henn
Rosanna, Melb
Re: GZE boost problems Thu, 07 October 2004 14:37 Go to previous message
And for the obvious one, check that your SC belt is TIGHT. And no air leaks post SC.
Hen
Previous Topic:1jz issues.. please help
Next Topic:EOI, group "buy" on porting an 18RG head
Current Time: Tue Oct 20 01:03:46 UTC 2026
Total time taken to generate the page: 0.0050079822540283 seconds
