Toymods » Tech & Conversions » Engine conversion - should I convert to manual at the same time?
Rattlehead
Engine conversion - should I convert to manual at the same time? Sat, 28 September 2002 07:59 Go to next message
Or is it too hard?
My car is a GA70 Supra...I'll be getting a JZA70 half cut which will be manual. I have been offered to swap the manual parts for auto parts, like the box, torque converter and stuff...
But anyway, if it had the parts, which it should (it's a front cut) would swapping it to man be difficult?
Youngy
Eskilstuna, Sweden
Re: Engine conversion - should I convert to manual at the same time? Sat, 28 September 2002 14:40 Go to previous messageGo to next message
If the front cut is a manual then making the change would be easy, all the bits would be there in place including the pedal box etc.
Rattlehead
Re: Engine conversion - should I convert to manual at the same time? Sat, 28 September 2002 15:24 Go to previous messageGo to next message
Awesome, if it's easy, I may as well swap it!
I love manual!!
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Engine conversion - should I convert to manual at the same time? Sun, 29 September 2002 00:47 Go to previous messageGo to next message
If you plan to swap to manual eventually, definitely do it now, cos every little bit you need (pedal cluster, crossmembers, bellhousings, master & slave cylinder, flywheel, clutch etc) will be a bitch to find without getting another front cut.
And if you love manual, why the hell would you swap a 5 spd for an auto??? Shocked
Rattlehead
Re: Engine conversion - should I convert to manual at the same time? Mon, 30 September 2002 10:25 Go to previous messageGo to next message
Coz autos are a dream to drive when ur in traffic like I am in every morning and every afternoon.
Well, I've decided to do the manual conversion...do I need a different tailshaft???
Re: Engine conversion - should I convert to manual at the same time? Mon, 30 September 2002 11:54 Go to previous messageGo to next message
Yes, you'll need a new front section as the W58 is a different length to the R154.
Rattlehead
Re: Engine conversion - should I convert to manual at the same time? Tue, 01 October 2002 10:26 Go to previous messageGo to next message
I think I got a A340E or something...1G auto.
JAZE
cronulla
Re: Engine conversion - should I convert to manual at the same time? Tue, 01 October 2002 11:33 Go to previous messageGo to next message
and also when they "offer to swap thae manual stuff for the auto stuff" they too forget that the looms are different and the loom in the manual half cut will not run the auto, and i dont think theyd bother swapping the looms over, you have to take the inlet manifold off to get it out.
Cressida Supra
Re: Engine conversion - should I convert to manual at the same time? Wed, 02 October 2002 17:17 Go to previous messageGo to next message
"I think I got a A340E or something...1G auto."
yeah, def need to lengthen/shorten d/s
mine is in getting done at the moment
A43DE -> W50
lenghtened by 85mm roughly $220
Peewee
Rattlehead
Re: Engine conversion - should I convert to manual at the same time? Thu, 03 October 2002 05:41 Go to previous messageGo to next message
SO I dont really need to get a new tailshaft, just modify my existing one??
I dont know what the tailshaft does, but I assume that power doesnt make any difference to the tailshaft I need.
So thats good.
Re: Engine conversion - should I convert to manual at the same time? Thu, 03 October 2002 08:27 Go to previous messageGo to next message
Yes you modify your existing tailshaft (well the front section anyway), but typically a driveshaft shop will just weld your existing flange and yoke to a new tube of the correct length.
Of course the easiest way would be to find a factory tailshaft from a JZA70 Supra, but they're probably not easy to find!
The strength of the tailshaft is very relevant to the power output of your engine, since the tailshaft transmits the power from the engine to the wheels! However I imagine all Mk3 tailshafts are the same spec (including turbo models) so it should be plenty strong.
Rattlehead
Re: Engine conversion - should I convert to manual at the same time? Thu, 03 October 2002 14:22 Go to previous message
Hmm...I hope ur right norbie, coz if anything, the tailshaft on my supra will be the weakest one, and then I'll be putting one of the most powerful supra engine in.
Previous Topic:AE86 Handling Mods
Next Topic:Heat when heater is OFF
Current Time: Tue Oct 20 01:06:18 UTC 2026
Total time taken to generate the page: 0.0072097778320312 seconds
