Toymods » Tech & Conversions » AFTERMARKET RPM METER ON 1G-GTE SOARER
indian
south east - melbourne
AFTERMARKET RPM METER ON 1G-GTE SOARER Thu, 07 October 2004 06:05 Go to next message
GUYS can anyone tell me weter I can fit an aftermarket rpm meter on a 1g-gte engined soarer , will I be able to use the rpm connections (pins) on the ecu plugs to get a sinal for the rpm meter to work ,(ive seen from the apexi safc wiring thats there two pins in the ecu that has the rpm signal this is what i was intending to use if its possible) im wanting to install a few gauges in the soarer and wanted to see if can do a rpm meter gauge any info appreciated
Smile Smile Smile Smile Smile Smile Smile
[Updated on: Thu, 07 October 2004 06:07]
Re: AFTERMARKET RPM METER ON 1G-GTE SOARER Thu, 07 October 2004 06:15 Go to previous messageGo to next message
Do you mean a TACHO??
If so, yes, its easy, and wanky
indian
Re: AFTERMARKET RPM METER ON 1G-GTE SOARER Thu, 07 October 2004 06:19 Go to previous messageGo to next message
forget the wank tell me how ,pleaseeeee i want to have some gauges on my dash and am running out of what to put oil pre , water temp , wanted 3 so tacho is the only one left other than oil temp have boost gauge on pillar alredy
But you already HAVE a tacho. Why on earth do you need two?
Re: AFTERMARKET RPM METER ON 1G-GTE SOARER Thu, 07 October 2004 06:20 Go to previous messageGo to next message
Tachos usually have 4 wires.
Tacho input (that comes from ignitor/coil/ecu), ignition, earth, and lights.
Just wire it up.
indian
Re: AFTERMARKET RPM METER ON 1G-GTE SOARER Thu, 07 October 2004 06:21 Go to previous messageGo to next message
oh btw its only one of those 2 inch ones ok , im not putting the fully sick 5 inch tacho on my dash
just for others who prob will flame me for
frankie -- just to see some needle action , sick of the digi dash now i loved my exa used to like seeing the tacho move around , now ive only got my boost meter so i though the tacho will be lively enuf to keep me happy
doesnt mater if it isnt perfectly accurate
[Updated on: Thu, 07 October 2004 06:23]
Re: AFTERMARKET RPM METER ON 1G-GTE SOARER Thu, 07 October 2004 06:24 Go to previous messageGo to next message
If its a decent one it will be more accurate than the factory one
indian
Re: AFTERMARKET RPM METER ON 1G-GTE SOARER Thu, 07 October 2004 06:26 Go to previous messageGo to next message
ok im no brain when it comes to electronics , so if i use the rpm signal from the ecu pin, will that do like i can run a wire from there right
then where to get ign signal from ca i use stereo one
[Updated on: Thu, 07 October 2004 06:28]
Re: AFTERMARKET RPM METER ON 1G-GTE SOARER Thu, 07 October 2004 06:29 Go to previous messageGo to next message
Stereo is accessories, not ignition.
Find out which wire goes to your factory tacho, and tap into that one.
Also, get a friend who knows what he is doing to help you.
indian
Re: AFTERMARKET RPM METER ON 1G-GTE SOARER Thu, 07 October 2004 06:45 Go to previous messageGo to next message
OK THANKS GUYS FOR THE HELP IIL SEE WHAT HAPPENS
thu187
Re: AFTERMARKET RPM METER ON 1G-GTE SOARER Thu, 07 October 2004 09:13 Go to previous message
CrUZsida wrote on Thu, 07 October 2004 16:29
LOL
I don't know if you intended that to be funny as well but it's pretty damn hilarious lol.
Previous Topic:MR2 SW20GT Ecu with ST162 Dizzy
Next Topic:ae86 20B convertion
Current Time: Mon Oct 19 01:59:34 UTC 2026
Total time taken to generate the page: 0.0058579444885254 seconds
