Toymods » Tech & Conversions » The Igniters function
SilverGhost
The Igniters function Thu, 07 October 2004 08:01 Go to next message
I have been reading up on toyota ignition systems a bit but I havent been able to find a source that explains the function of an igniter.
Is it an amplifier for an ECU signal, or does it function as more of a sensor?
Basically, what does the bloody thing do hehe, and what would be the symptoms if one isnt functioning correctly??
GTS_215KW
Re: The Igniters function Thu, 07 October 2004 09:04 Go to previous messageGo to next message
basically it is an amplifier man, and depending on the type of igniter it might also control the dwell time of the coil. if it wasnt working you would either have weak spark or no spark at all.
SilverGhost
Re: The Igniters function Thu, 07 October 2004 09:13 Go to previous messageGo to next message
cool thanks man, the MR2 BGB Online Manual is great for diagnosing 2nd Gen 3sgte problems
http://www.mr2-tech.com/bgb/mechanical/index_mecha nical.htm
But does not go into explaining the function of a part.
Re: The Igniters function Thu, 07 October 2004 12:20 Go to previous messageGo to next message
igniter.
takes the input (such as hall effect or VR) and either conditions signal to fire the transistor that grounds the coil.
or conditions signal to send to ECU which sends back and that signal then fires the transistor that grounds the coil.
igniters 'usually' (perhaps?) control the dwell. timing is either controlled by the dizzy, or the ECU.
ae86drift
sydney.au
Re: The Igniters function Thu, 07 October 2004 12:28 Go to previous messageGo to next message
what about in a 4age ae86 O.C.?
SilverGhost
Re: The Igniters function Fri, 08 October 2004 05:47 Go to previous message
Thanks for the info guys...sounds like its one of those modules that either works or it just doesnt in which case, the car would not run (or run sick as a dog) mine runs fine after starting so im going to look towards a fuel related problem.
Yeah, toyota only supply a elec. diagram of the unit, no way for even toyota techies to test it, manual just says 'no IGF or IGT signal - Replace igniter' hehe
cheers!
Previous Topic:Brake master cylinder sizes
Next Topic:Blitz Dual SBC Spec R Manual
Current Time: Sat Oct 24 01:38:35 UTC 2026
Total time taken to generate the page: 0.011507987976074 seconds
