Toymods » Tech & Conversions » are all W50's the same
Mr DOHC
are all W50's the same Thu, 07 October 2004 08:07 Go to next message
basically, i wanna put a 5 speed in my RT104, i have the oportunity to get a W50 from an RA28, does anyone know if its a direct bolt in, or do i need more stuff, i.e. tailshaft, different shifter location
Re: are all W50's the same Thu, 07 October 2004 08:43 Go to previous messageGo to next message
Assuming your RT104 currently was a W40 4-speed, it's a direct swap. Be aware there are at least 2 different shifter positions on the W50 though, so make sure you get the right one. Get your tape measure out!
Mr DOHC
Re: are all W50's the same Thu, 07 October 2004 08:50 Go to previous messageGo to next message
yes its the W40, where do i measure to and from, are the ratios the same in the W40 and 50
Re: are all W50's the same Thu, 07 October 2004 08:53 Go to previous messageGo to next message
If you stop and think about it for about a second, the answer is pretty obvious... but since I'm in a good mood, measure from the front edge of the bellhousing to the shifter.
AFAIK the 1-4 ratios are the same, but I'm not 100% certain.
Re: are all W50's the same Thu, 07 October 2004 09:00 Go to previous messageGo to next message
IIRC, the W40 and W50 shifter positions are interchangable.
So you can use your old one in the new box.
http://oz-enet.com.au/~peewee/yoda_boxes.html
Mr DOHC
Re: are all W50's the same Thu, 07 October 2004 09:05 Go to previous messageGo to next message
thanks norbert
Norbie wrote on Thu, 07 October 2004 18:53
y u happy, get some http://image-cache.boostcruising.com/forums/html/emoticons/thumbsup.gif
matt_84
Ipswich
Re: are all W50's the same Thu, 07 October 2004 09:06 Go to previous messageGo to next message
mrdohc, my w50 is 635mm bellhousing to shifter. or 580mm to the front of the shifter plate.
river
Land of Oz
Re: are all W50's the same Thu, 07 October 2004 11:05 Go to previous messageGo to next message
Can't you change the shifter position? You just need to take off the shifter plates (or whatever they're called) from your existing box to the new box (assuming they're in different positions).
Also I thought that the gear ratios can be different in the W50 gearbox, depending what type of car it came from.
seeyuzz
river
Mr DOHC
Re: are all W50's the same Thu, 07 October 2004 11:27 Go to previous messageGo to next message
i had a read of cruZsida's lin k and it says the RG box's had a longer 1st on them
i have my RT104 book at home, i'll compare the ratios
crazedrt104
Darwin
Re: are all W50's the same Thu, 07 October 2004 22:29 Go to previous message
DOHC...the w50 i put in my 104, the shifter sat about 35-40 mm futher forward then the 4 speed...i didnt have to change tailshaft, and i didnt have to get a new g/box xmember. not sure if i used the 4 speed one or the 5 speed
Previous Topic:ST185 Starting Problem
Next Topic:Independant Throttle Body Questions
Current Time: Fri Oct 23 16:34:12 UTC 2026
Total time taken to generate the page: 0.0043470859527588 seconds
