Toymods » Tech & Conversions » Independant Throttle Body Questions
Farmsci ST162
Independant Throttle Body Questions Thu, 07 October 2004 11:12 Go to next message
Can someone tell me what problems you can encounter running a quad throttle setup on a standard ECU? Engine uses a map sensor. But where would you hook up the vac lines with quad throttles? Injectors to run off factory fuel rail plugging into the head (unlike some ITB setups that inject into the intakes).
Some people have told me it'll be rough at idle but otherwise fine others have said it wont work properly unless I use an aftermarket ecu mapped for it. So i figured id throw this one up in the air for discussion. Any help would be greatly appreciated.
Steve
Re: Independant Throttle Body Questions Thu, 07 October 2004 12:55 Go to previous messageGo to next message
I do believe this has been discussed before - hit the search button Laughing
Re: Independant Throttle Body Questions Thu, 07 October 2004 21:47 Go to previous message
You will most definitely need a programmable ECU to run ITB's.
Previous Topic:are all W50's the same
Next Topic:7MGTE Auto 2 Man
Current Time: Fri Oct 23 12:44:37 UTC 2026
Total time taken to generate the page: 0.0049431324005127 seconds
