Toymods » Tech & Conversions » 3t motor? 18rg motor?
MRW00Z
Mudgee NSW
icon9.gif  3t motor? 18rg motor? Thu, 07 October 2004 11:36 Go to next message
Hi, hopefully someone can share some advice. In a bid to up the power in my 1983 18RC hilux I purchased from my local wreckers what I was told was an 18rg engine. Has twin webbers, extractors and 5 spd for $700. Gets it home and finds an engine number '3T....!' The head looks very much 18RG so now I'm not sure! Can an 18RG head be put on a 3T block. Should I kick up a stink and demand $$ back or should I just try what I've got 'cause anything would be better than an 18rc? The part number on the front of the head is 11111-88260. any help/recomendations would be appreciated.
greenta22
Dandenong Ranges, VIC
Re: 3t motor? 18rg motor? Thu, 07 October 2004 11:56 Go to previous messageGo to next message
sounds like you've got a 2TG/3T hybrid. 11111-88260 is a 2TG head, and if the block has 3T stamped into it, then thats definately the case. it will be 1770cc if it has the standard bore and a 3T crank. these motors are generally hotter than an 18RG, but your problem will be putting it in your hilux, as its a T-series block, not R series you will need to fabricate engine mounts etc to get it to fit. Id take it back and get an 18RG. much easier.
SeptemberSquallIndustries
Re: 3t motor? 18rg motor? Thu, 07 October 2004 11:57 Go to previous messageGo to next message
It's a 2T/3T hybrid. 88260 is a later model EFI 2T-G head, the 3T block is probably 78mm stroke, 85mm bore for 1770CC. Have a close look at the motor, the distributor sits at a different angle and the top water outlet/thermostat is on the other side of the head relative to 18R-G.
Not a bad motor in its own right but definately not a bolt-in proposition for your Hilux!
Edit: Fuck, too slow.
[Updated on: Thu, 07 October 2004 11:58]
pheonix83
Devonport Tasmania
Re: 3t motor? 18rg motor? Fri, 08 October 2004 00:32 Go to previous messageGo to next message
it also, may be just a plain old 2tg just using the 3t block.
if thats the case, they are fairly gutless.
but have good potential
MRW00Z
Mudgee NSW
Re: 3t motor? 18rg motor? Sat, 09 October 2004 00:47 Go to previous message
Thanks for the tips guys. Will see if I can offload this motor and try again!! Cheers
Previous Topic:Not evenly lowered??? why
Next Topic:85 Corona steering help
Current Time: Sun Oct 18 03:00:47 UTC 2026
Total time taken to generate the page: 0.16607785224915 seconds
