Toymods » Tech & Conversions » Interesting Compression Test Results
icon9.gif  Interesting Compression Test Results Thu, 07 October 2004 15:24 Go to next message
Well, finally did a compression test on the old 1GGTE. It's been a long while since the engine has been run, I've had it for a while, and JMS had it for a few months before I purchased it.
This was a cold compression test having not being run for a while, so we weren't quite sure what to expect...unfortunately, it wasn't this.
From 6 to 1:
110 60 85 120 95 25
Talk about consistency! Sad Anyone else experienced this problem? If so, what was the problem?
Thanks,
Nathan
Re: Interesting Compression Test Results Thu, 07 October 2004 15:26 Go to previous messageGo to next message
Dammit, wrong window, can someone please move this to the tech section... Embarassed
EMP-2TG
Carlingford, Sydney
Re: Interesting Compression Test Results Thu, 07 October 2004 15:41 Go to previous messageGo to next message
has it got oil in it?
mmm healthy Sad
Re: Interesting Compression Test Results Thu, 07 October 2004 15:42 Go to previous messageGo to next message
Sure does have oil in it. Cranking over fine, at least the 1GEU starter still works fine!
CLG
Perth, Western Australia
My experience has beenthat engines that sit over time will not seal as well as an engine that has had a heat cycle put through it - run it, get it warm to let valves reseat and everything to operate as normal, then compression test it. i'd still do the compression test cold after the heat cycle and then also warm to compare results and determine condition.
Previous Topic:ta22 body and interier mods
Next Topic:1jz issues.. please help
Current Time: Mon Oct 19 15:50:12 UTC 2026
Total time taken to generate the page: 0.0043179988861084 seconds
