Toymods » Tech & Conversions » Quick stupid question on JDM 4AGE
Johnny_K
Perth WA
Quick stupid question on JDM 4AGE Thu, 07 October 2004 15:29 Go to next message
Hey just wondering if a FWD JDM 4AGE water pump, is exactly the same design as a AUS spec FWD 4AGE water pump ???. THANKS JoHnNy_K
siriuspower
Re: Quick stupid question on JDM 4AGE Thu, 07 October 2004 20:05 Go to previous messageGo to next message
No they are different because water rotates in a different direction, depending which hemisphere you live in. You would have to install your thermostat backwards.
ae86trueno
Re: Quick stupid question on JDM 4AGE Thu, 07 October 2004 22:17 Go to previous messageGo to next message
AFAIK they should be interchangeable, its only the RWD water pump that is slightly different,
For the water to rotate in a different direction the engine would have to spin in the oppisite direction !!!
Ben.
[Updated on: Thu, 07 October 2004 22:18]
Corona RT142
Campbelltown
Re: Quick stupid question on JDM 4AGE Fri, 08 October 2004 02:12 Go to previous messageGo to next message
sirius power, while that comment is well accepted many experts dispute claims. The direction water flows has more to due with the shape of the object it is in, the correliuos effect has been argued to be a bit of a crock of shit.
Johnny_K
Perth WA
Re: Quick stupid question on JDM 4AGE Fri, 08 October 2004 02:32 Go to previous messageGo to next message
Hahahahahahah ok it seems i no problems with instaling a AUS spec water pump then. Now just wondering when you buy a water pump does it come with that little attachment that holds the pulley, because my other one is worn out i guess because the previous owner attached his 4ac fan onto the pump. THANKS JoHnNy_K
ae86trueno
Re: Quick stupid question on JDM 4AGE Fri, 08 October 2004 02:53 Go to previous messageGo to next message
Yes the water pump comes with the shaft that the pulley polts onto, just dont EVER bolt a fan to a FWD water pump, it will rip the pump apart (among other things) as its not strong enough to support it.
Ben.
ae95
Re: Quick stupid question on JDM 4AGE Fri, 08 October 2004 04:40 Go to previous messageGo to next message
yerp, the fwd pumps werent designed to hold the weight and force of a clutch fan, neither were the bearings. you need to get a hold of a electric thermo fan.
EvilJack
Sutho/Hills NSW
Re: Quick stupid question on JDM 4AGE Fri, 08 October 2004 04:53 Go to previous messageGo to next message
careful doing up the water pump aswell, you dont want any 10mm bolts snapping inside the block Rolling Eyes
SeptemberSquallIndustries
Re: Quick stupid question on JDM 4AGE Fri, 08 October 2004 04:58 Go to previous messageGo to next message
siriuspower wrote on Fri, 08 October 2004 06:05
Shocked
Re: Quick stupid question on JDM 4AGE Sat, 09 October 2004 01:58 Go to previous messageGo to next message
the FWD and RWD water pumps are very different!!
# the RWD pump has the small pipe that comes down from the top water outlet, and also holds the thermostat in the rear housing - you need the top outlet and water pump matched to either both FWD or BOTH RWD
# if you use the FWD one, you will need a remote thermostat housing... see my "HOW TO: FWD to RWD water conversion" thread
Re: Quick stupid question on JDM 4AGE Sat, 09 October 2004 04:09 Go to previous message
THE WITZL wrote on Sat, 09 October 2004 11:58
Actually if you read the first post you'll realise he's asking about JDM FWD pump compared with local FWD pump.
Previous Topic:1jz twin dump pipes
Next Topic:RA23 flasher can
Current Time: Sat Oct 17 06:07:52 UTC 2026
Total time taken to generate the page: 0.0059080123901367 seconds
