Toymods » Tech & Conversions » Sythetic tranmition oil in A340
BLK1GGTE
South Eastern Subs
Sythetic tranmition oil in A340 Fri, 08 October 2004 00:41 Go to next message
Can i use sythetic ATM in the A340.. I know sythetic oil is a better oil and more heat resistant so just wanted to know if the trany will be ok with it..and i know you can't mix mineral with sythetic...so i have to drain out all off the old oil out of the box first...
The A340 holds about 2 litres is this correct?? Thanks ppls
Chris Davey
sunny coast, qld
Re: Sythetic tranmition oil in A340 Fri, 08 October 2004 02:18 Go to previous message
not sure about the synthetic issue but the A340 should hold 1.6L if it the same as the 1jz one.
have a look at your auto dipstick and see what it recommends on there. Then do a search on auto a340 fluid and you will get a heap of responses Smile
Just check to make sure that the 1g auto uses the same fluid as the 1jz auto. I can't remember.
Previous Topic:4AGZE + 164mm/175mm crank pulley-HELP!
Next Topic:18R-G pointless dizzy fit in 2tg?
Current Time: Sat Oct 24 04:54:13 UTC 2026
Total time taken to generate the page: 0.0047049522399902 seconds
