Toymods » Tech & Conversions » 4AGZE + 164mm/175mm crank pulley-HELP!
Michael P
icon5.gif  4AGZE + 164mm/175mm crank pulley-HELP! Fri, 08 October 2004 02:01 Go to next message
Are any of you guys running 164/175mm crank pulleywith factory ecu. What I am wondering is whether there have been any fuel issues once an oversize pulley has been fitted to drive the SC. I am aware that the IC will need to be improved to use these pulleys but if you guys had any problems with fuel how did you fix them? Advice from someone that has actually done this mod would be appreciated.
Re: 4AGZE + 164mm/175mm crank pulley-HELP! Fri, 08 October 2004 02:17 Go to previous messageGo to next message
Factory management can handle up to 14-15psi on the MAP sensor versions, as the MAP sensor is a 2-bar type.
cooling is at its limits with the 164mm pulley, and with the 175mm pulley a cooler upgrade is required.
if you have an AFM type GZE, i really dont know what the factory management can handle.
Ben Wilson
Re: 4AGZE + 164mm/175mm crank pulley-HELP! Fri, 08 October 2004 02:24 Go to previous message
Mr mr2 used to lean out down low with the big pulley, but, was fine up higher in the rev range.
Previous Topic:Exhaust Question about 4AGE 16v swap into AE86
Next Topic:Sythetic tranmition oil in A340
Current Time: Sat Oct 24 04:54:26 UTC 2026
Total time taken to generate the page: 0.004148006439209 seconds
