Toymods » Tech & Conversions » ISCV Workings - ANSWERS
ISCV Workings - ANSWERS Fri, 08 October 2004 02:10 Go to next message
How does a non-stepper 3 wire ISCV work?
I know you have 12volts to the centre, but what about the other 2 wires?
Does the ECU just ground one wire, thus openening the ISCV fully?
And then ground the other wire, thus closing the ISCV fully?
Is it this simple?
Or am I missing something?
I know steppers are much more intricate, but I don't need to know how they work.
[Updated on: Fri, 08 October 2004 02:41]
Re: ISCV Workings - ANSWERS Fri, 08 October 2004 02:41 Go to previous messageGo to next message
http://www.autoshop101.com/forms/h26.pdf
Its a good read too
Re: ISCV Workings - ANSWERS Fri, 08 October 2004 03:03 Go to previous messageGo to next message
if you are talkign abotu the rotary solenoid type (page 6), i have one of those and will be makingup a circuit to have in-car idle speed adjustment.
is just a 250Hz circuit which alternately grounds one coil or the other.. can't be that hard Wink (tho i have little electronic design idea Very Happy )
failing that, a good old swagelok valve will be used.
Re: ISCV Workings - ANSWERS Fri, 08 October 2004 04:33 Go to previous messageGo to next message
Well, the whole point of this was to see if I could run my stepper ISCV with a PWM output, which I have found out to my dismay that I can't
Looks like I will have to get a 4AGZE ISCV and make up some bracket thingy to suit it.
Henn
Rosanna, Melb
Re: ISCV Workings - ANSWERS Fri, 08 October 2004 04:41 Go to previous messageGo to next message
I'd imagine it'd be possible to get PWM -> stepper to work, but for the circuitry you'd need it'd probably be easier to change to a rotary solenoid. Could be a fun project though, and leave you with the factory idle control unit.
Hen
Re: ISCV Workings - ANSWERS Fri, 08 October 2004 04:44 Go to previous message
I'll just get a factory one off another Toyota Motor.
Previous Topic:difference between horizontal and vertical Webers
Next Topic:Any gen 2 3sgte's around the campbelltown area?
Current Time: Sat Oct 24 04:38:28 UTC 2026
Total time taken to generate the page: 0.0062439441680908 seconds
