Toymods » General Car Talk » Stud Pattern for the KE25
sloanes
Stud Pattern for the KE25 Fri, 08 October 2004 05:06 Go to next message
What is the stud pattern for the KE25 ?
schnitzel
Bendigo
Re: Stud Pattern for the KE25 Fri, 08 October 2004 07:50 Go to previous messageGo to next message
KE20/25 have different stud pattern to other toyotas but share it with early rwd mazdas, hence 808,rx2,3,4or7 early 929 wheels fit. NOTE mazda 121 and rx5 do not fit. From memory I think it is 4 x 110mm instead of 4 x114.3mm
regards
Tommo
theres a castle on my hil...
Re: Stud Pattern for the KE25 Fri, 08 October 2004 07:58 Go to previous messageGo to next message
what he said ^
are you looking for rims to suit a KE25?
Re: Stud Pattern for the KE25 Fri, 08 October 2004 08:27 Go to previous messageGo to next message
i'm always looking Smile
15x6 superlights would be nice Wink
Tommo
Re: Stud Pattern for the KE25 Fri, 08 October 2004 10:11 Go to previous messageGo to next message
lol, i wouldnt mind some 14 to 16 inch watanabes in that stud pattern either Cool
Tommo
Re: Stud Pattern for the KE25 Sat, 09 October 2004 03:38 Go to previous messageGo to next message
oldcorollas wrote on Fri, 08 October 2004 18:27
I thought that my brother had heaps of wheels in 4x110pcd but then i found out his KE25 has been converted to 114.3
purple_people_eater_1
Hobart, Tasmania
Re: Stud Pattern for the KE25 Sat, 09 October 2004 15:13 Go to previous messageGo to next message
I have 2 sets, hot wires, 12x5 one set has brand new tyres. gold centred with silver rim, or all silver.
anyone interested?
PMP020
January 2005
Re: Stud Pattern for the KE25 Sat, 29 January 2005 06:26 Go to previous messageGo to next message
i wood b very interested in ur hotwires if u want 2 send em 2 adelaide ?
bassy
Re: Stud Pattern for the KE25 Sat, 29 January 2005 10:30 Go to previous messageGo to next message
tomo- do you know how they converted the rear wheels to 114.3?
Hobart, Tasmania
Re: Stud Pattern for the KE25 Sun, 30 January 2005 02:05 Go to previous message
PMP020: you have PM
bassy : to change the stud patten the easiest way I think is to:
(Everyone feel free to correct me as Im sure there are better short and cheaper alternatives?)
use the struts from another toyota eg. corolla, celica. along with the lower control arms (longer control arms provide more negative camber best to stay the same length or a little longer) and caster ajustment rods from the same car. compress the springs remove the strut top and replace with the strut top from your car.
for a stud pattern change on the rear you could use a KE3*, these may need some minor adjustment to the brackets to line up the springs and get the diff centre in correct placement. and new u bolts not sure if axle is the same width?
In my Ke20 I have a jap spec AE86 disc brake and LSD diff which has been sortend and adapted to suit the KE20 suspenion. Up front I have celica strust with lowered incerts, 313mm slotted rotors and twinspot calipers, I have used celica control arms and caster rods, the celica control arms are not long enough so I have Kmac adjustable strut tops top correct carster and camber, however I will extend these to allow for more adjustment.
Cheers Kieran
Previous Topic:ke10 4age
Next Topic:Toyota Crown project coming soon...
Current Time: Thu Nov 19 23:19:45 UTC 2026
Total time taken to generate the page: 0.0063731670379639 seconds
