Toymods » Tech & Conversions » Variable valve timing on 20v gze turbo?
MRKE20
wollongong
Variable valve timing on 20v gze turbo? Fri, 08 October 2004 05:38 Go to next message
i have just had my car dyno'd and it seems that my vvt on my 20v head is not hooked up. is this the thing with two wire sticking out on the front left of the head? if it is its not hooked up and could this have caused the problems at the top end of my dyno run? it goes up, then drops, then up, then drops.like its kicking in then dropping.(fluctuating at top end)
does any1 here know what i should do, hook it up or leave it off? if im wrong on its possition where is it then?
AE86slut
Baulko Hillo
Re: Variable valve timing on 20v gze turbo? Fri, 08 October 2004 05:58 Go to previous messageGo to next message
Yes, that's the plug. Is it wired to anything or not? Which computer are you using?
MRKE20
wollongong
Re: Variable valve timing on 20v gze turbo? Fri, 08 October 2004 06:57 Go to previous messageGo to next message
its unplugged and not hooked up at all. im running a microtech LT-8.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Variable valve timing on 20v gze turbo? Fri, 08 October 2004 06:59 Go to previous messageGo to next message
If it's a GZE bottom end the block won't have the oil gallery needed to supply oil pressure to actuate the variable cam timing. What are your tuners thoughts on the problem?
AE86slut
Baulko Hillo
Re: Variable valve timing on 20v gze turbo? Fri, 08 October 2004 07:22 Go to previous messageGo to next message
I would be inclined to suggest that the VVT is not the cause of your rpm fluctuation. A faulty actuator could possibly cause it, but seing as yours isn't connected at all, I can't see how it would be that.
Flem
cambo
Re: Variable valve timing on 20v gze turbo? Fri, 08 October 2004 12:30 Go to previous message
one wire should be a constant voltage 12v and the other should be switched from the ecu i think
[Updated on: Fri, 08 October 2004 12:33]
Previous Topic:Lowered springs on std shocks
Next Topic:3sgte knock sensor wiring problems!
Current Time: Thu Oct 22 14:53:12 UTC 2026
Total time taken to generate the page: 0.0049140453338623 seconds
