Toymods » General Car Talk » what on earth is this??
Jag7799
what on earth is this?? Fri, 08 October 2004 10:18 Go to next message
http://members.optushome.com.au/jag7799/fuel.jpg
this thing is on my main fuel supply line going into my injector rail right under the firewall and just infront...
the line infront of it is my return line.
I want to know what the big thing that ive circled is.
is it the fuel filter?, if so i was informed the 1jz had a fuel filter mounted to the block.. would that in turn mean the person who did my conversion did something silly and is running 2 fuel filters?..
if its not, what is it?
monkeymajik
Re: what on earth is this?? Fri, 08 October 2004 10:21 Go to previous messageGo to next message
it looks like a fuel filter to me
Jag7799
Re: what on earth is this?? Fri, 08 October 2004 10:29 Go to previous messageGo to next message
but on 1j's arent they meant to be on the block???? if so.. where exactly?
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: what on earth is this?? Fri, 08 October 2004 11:33 Go to previous messageGo to next message
Looks lik a fuel filter to me...
As for finding one on the block... Follow your fuel lines...
My guess is that you won't find one.
STR8 2.8
Re: what on earth is this?? Fri, 08 October 2004 11:45 Go to previous messageGo to next message
a huge pulsation dampener?
Jag7799
Re: what on earth is this?? Fri, 08 October 2004 12:11 Go to previous messageGo to next message
STR8 2.8 wrote on Fri, 08 October 2004 21:45
how would i tell the difference
im running like a 600 hp pump.. maybe even higher
what are some tell tale signs of what it is
warrior
Sydney / NSW
Re: what on earth is this?? Fri, 08 October 2004 12:29 Go to previous messageGo to next message
your car may have warts
SeptemberSquallIndustries
Re: what on earth is this?? Fri, 08 October 2004 12:41 Go to previous messageGo to next message
Fuel filter?
Fuel pulse dampener?
Regulator?
Jag7799
Re: what on earth is this?? Fri, 08 October 2004 12:45 Go to previous messageGo to next message
which one is it?
or tell tale signs of each one
improvedae86
Re: what on earth is this?? Fri, 08 October 2004 12:46 Go to previous messageGo to next message
Some-type of FUEL POLARIZER , or fuel saver gimmick ?
river
Land of Oz
Re: what on earth is this?? Fri, 08 October 2004 12:48 Go to previous messageGo to next message
Rip it out and pull it apart. It's the only way you're gonna know for sure. Smile
seeyuzz
river
Jag7799
Re: what on earth is this?? Fri, 08 October 2004 12:57 Go to previous messageGo to next message
no pulling apart Sad
Re: what on earth is this?? Fri, 08 October 2004 13:01 Go to previous messageGo to next message
Do you have another fuel filter in the high-pressure line? If not, it's a fuel filter. If you do, it's probably not a fuel filter.
Do you have a pressure regulator on the fuel rail? If not, it's a pressure regulator. If you do, it's probably not a pressure regulator.
Jag7799
Re: what on earth is this?? Fri, 08 October 2004 13:09 Go to previous messageGo to next message
SeptemberSquallIndustries wrote on Fri, 08 October 2004 23:01
lol.. i guess ill have a look tomorrow
Siktoy ra23
Plumpton/sydney
Re: what on earth is this?? Fri, 08 October 2004 14:30 Go to previous messageGo to next message
It wont be your fuel regulator that should be on your fuel rail my guess is a fuel filter I would pull it of and have a look if it is a fuel filter change it for a new one, Id say it may need it
BEN
Jag7799
Re: what on earth is this?? Fri, 08 October 2004 14:33 Go to previous messageGo to next message
Siktoy ra23 wrote on Sat, 09 October 2004 00:30
BEN
it might be new one.. its just been covered in alloy shavings and crap and paint overspray
ill check it out..
how do i tell exactly?.. and whats a new one cost abouts
Danish
Re: what on earth is this?? Fri, 08 October 2004 15:23 Go to previous messageGo to next message
By the looks of it, it won't do any harm taking it out. Do you have a fuel filter on it somewhere?
On a GZ20 Soarer the stock fuel filter is fixed above the differential. I had this taken out as it was old and I already had a new Ryco fuel filter on the fuel line.
Take it out and put a Ryco fuel filter in its place.
Chris Davey
sunny coast, qld
Re: what on earth is this?? Sat, 09 October 2004 00:16 Go to previous messageGo to next message
looks like fuel filter to me
stock fuel filter is right behind the left engine mount
there are at least two different types
my chaser engine has a much larger one than my soarer engine
BTW if anyone is looking for a 1jz fuel filter there is one somewhere on the grandstands at willowbank that I left there Confused Embarassed
pressure regulator is the thing on the end of the fuel rail that has a return line on it and an air pipe going into the plenum
EVOSTi
cambo
      no
Re: what on earth is this?? Sat, 09 October 2004 00:20 Go to previous messageGo to next message
dood if you dont know what that is, i think you should take your car to a mechanic and avoid working on it yourself at all costs.
Jag7799
Re: what on earth is this?? Sat, 09 October 2004 00:51 Go to previous messageGo to next message
okay.. i beleive its new and its a fuel filter..
its an FSA one
I get 1.9 litre a minute out of my return line, is that okay?
EVOSTi
cambo
      no
Re: what on earth is this?? Sat, 09 October 2004 07:57 Go to previous messageGo to next message
there is no "ok" for the fuel flowing from your return line. whatever the engine doesnt use it doesnt use!
dont just say you believe its a new fuel filter, the first thing you do when you get a car is change the oils and filters. for the sake of a $3 fuel filter youve got peice of mind.
Jag7799
Re: what on earth is this?? Sat, 09 October 2004 08:51 Go to previous messageGo to next message
EVOSTi wrote on Sat, 09 October 2004 17:57
or i could save 3 dollars and ring the guy who did the conversion and ask him if he changed the filter
Also, that fuel test was just with ignition to acc... no motor running
if that changes anything
Re: what on earth is this?? Sat, 09 October 2004 12:43 Go to previous messageGo to next message
Jag7799 wrote on Sat, 09 October 2004 18:51
or you could look at the thing and if it doesn't look new, then it's probably old... is your engine, and it's just outside your house? guy who did conversion probably wont remember or will tell you BS anyway?
also... fuel pressure is the thing to monitor, not return fuel volume. Yes having the engine running may make a difference - to fuel rail pressure - but the pressure regulator's job is to maintain that pressur regardless of engine behaviour.
is the engine warning light coming on at all? and have you tried to check for any diagnostic codes from the ECU (do a search for extracting error codes from 1JZ)
Jag7799
Re: what on earth is this?? Sun, 10 October 2004 02:40 Go to previous message
Fuel filter looks new so im assuming it is.
I think the original filter has been taken off the engine..
no warning light at all.
With the boosting problems it was having.. im starting to think it might have been a kink in boost controller lines or something rather than something wrong with a car
cause boost with controller on most open setting was 14 psi.. but was only 11 without
should with an open boost controller only go up to 12 or so
Previous Topic:teh GTR can nevAh lo53...
Next Topic:What's the go with drift damage and and that monkey sticker?
Current Time: Mon Oct 19 01:08:01 UTC 2026
Total time taken to generate the page: 0.012764930725098 seconds
