Toymods » Tech & Conversions » 3sgte knock sensor wiring problems!
tooch
Bulleen, Melbourne
3sgte knock sensor wiring problems! Fri, 08 October 2004 11:00
Hoping someone can help me Smile
I swapped the knock sensor over in my ST185, but I am still getting a code 52 (knock sensor problem). I am thinking it must be the wiring then, as there appeared to be some resistance between the knock sensor wire and the ground when I measured it. I also tried testing between the knock sensor terminal and the wire going to the ecu (assuming I had the right one), and got no connection according to the mulitmeter. Should there be a direct connection there?
If so, am I able to just run a whole new shielded wire from the knock sensor straight to the terminal on the ecu? Or is there more to it than that?!
Please help!
Previous Topic:Variable valve timing on 20v gze turbo?
Next Topic:Someone to do 4agze conversion for AE92
Current Time: Thu Oct 22 13:55:12 UTC 2026
Total time taken to generate the page: 0.0068140029907227 seconds
