Toymods » Tech & Conversions » What camber do you run on your car ?
Les
icon5.gif  What camber do you run on your car ? Fri, 08 October 2004 14:21 Go to next message
I am asking this because my RA65 Celica has some wierd camber happening up front ... -3 (left) and -1(right) ... probably from the earlier prang
Although the Celica has no front camber adjustment, it can be fixed by bending bits and pieces here and there I guess...
SO what I want to ask is what camber do you run on your car for road use ??
Re: What camber do you run on your car ? Fri, 08 October 2004 14:30 Go to previous messageGo to next message
-2.5 a side on my KE70, made an unbelievable difference over the positive camber that was there before, absolutely ENORMOUS difference.
lang
Re: What camber do you run on your car ? Fri, 08 October 2004 15:27 Go to previous messageGo to next message
yes camber is good,
allthough
i have excessive camber in the rear (more than at the front, like double) and in the wet i have absolutley no traction in the rear, at 1.4 throttle driving in the hills at 60 the tail has no traction during any cornering, its probably pretty dangerous id never let anyone else drive it in the wet.. fun tho
Les
Re: What camber do you run on your car ? Fri, 08 October 2004 19:23 Go to previous messageGo to next message
Mrshin - what is the tyre wear like at -2.5 ??
Lang ... what tyres are u using and why so much camber at the back ? and what car is it etc?
EMP-2TG
Carlingford, Sydney
Re: What camber do you run on your car ? Fri, 08 October 2004 23:54 Go to previous messageGo to next message
i run -1.5 and dont notice any tyre wear really
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: What camber do you run on your car ? Sun, 10 October 2004 05:10 Go to previous messageGo to next message
i hear ya man. my ra60 has serious tyre wear on the outsides of the wheels. crappy positive camber.
i've been told apparently u can use mx83? lower control arms to give more neg camber. i think u have to mod the lower strut mount tho.
RWDboy
Re: What camber do you run on your car ? Sun, 10 October 2004 05:34 Go to previous messageGo to next message
I generally find that about -1.0 degrees camber is fine. Anything more is kind of excessive for a street car. If you want to really alter the way your car behaves then fiddle with the toe-in and then match your camber to even out the tyre usage.
Re: What camber do you run on your car ? Sun, 10 October 2004 05:36 Go to previous messageGo to next message
Try MX73 if you're looking for a little bit James, you've got to mod the steering arms to suit though. I've got a set thats been done lying around too Evil or Very Mad
Tyre wear? Actually it's only been there a couple of weeks, so I haven't quite destroyed the tyres yet. Oh darn..
Purple_Beasty
New Zealand
Re: What camber do you run on your car ? Sun, 10 October 2004 07:45 Go to previous messageGo to next message
http://img35.exs.cx/img35/3530/camber.jpg
ae86drift
sydney.au
Re: What camber do you run on your car ? Sun, 10 October 2004 08:20 Go to previous messageGo to next message
around -2.5 on my ae86
tire wear is minimal.
IRA11Y
Club Member
Re: What camber do you run on your car ? Sun, 10 October 2004 09:11 Go to previous messageGo to next message
hey mrshin, how much castor are you running??
monkeymajik
Re: What camber do you run on your car ? Sun, 10 October 2004 11:58 Go to previous message
-1.27 on the front, need adjustable camber tops!
Previous Topic:20V head on 4agze (VALVE vs PISTONS)
Next Topic:HELP !
Current Time: Sat Oct 17 23:02:26 UTC 2026
Total time taken to generate the page: 0.0051519870758057 seconds
