Toymods » Tech & Conversions » MA70 Tail Light Warning, I think
Maphril
God's Country (Cronulla)
MA70 Tail Light Warning, I think Fri, 08 October 2004 23:53 Go to next message
G'day members...
Would anybody be able to let me know what the orange light showing a picture of a car with what would seem it's rear lights on and also the two orange, squarish lights are on above the wheels on the picture of the car. (This is the MA70 with digital dash by the way).
I assumed that the lights represented a busted tail light as it used to come on during rain as the lens does not seal properly and was most likely shorting out a lamp.
Eventually it blew a lamp altogether that I changed but the warning light is still present. Confused
Is this a tail light warning light or can it also represent another fault?
Thanks,
Matt Cool
lumpy
Adelaide, SA
Re: MA70 Tail Light Warning, I think Sat, 09 October 2004 08:29 Go to previous messageGo to next message
It means the tailights are blown (or brake lights, or bad earth in the tailights). Check the online TSRM for MA70 as I a little sketchy as to if it means anything else. I blew 1 rear brake light, then the rest followed in quick sucession. Have you checked the operation of all tailights yet?
dingaling
tas
Re: MA70 Tail Light Warning, I think Sat, 09 October 2004 12:20 Go to previous messageGo to next message
yep what lumpy suggested.
I had the same problem, and most of the lightbulb connections for the brake lights were corroded and shorting out, i cleaned all the bulb sockets with a file and installed new bulbs (old ones were burnt out), that fixed it, and the warning light dissapeared.
I also have the digital dash, When my brake lights were buggered i only got the mini car icon and not the the two orange, squarish lights on above the wheels, i heard they might indicate the headlights are blown/inoperative, so check all your lights work.
Maphril
Re: MA70 Tail Light Warning, I think Mon, 11 October 2004 03:13 Go to previous messageGo to next message
I had somebody check the brake lights yesterday for me and they said they all lit up correctly. I've checked the reverse lights and indicators front and rear as well as parker lights and anything else with a bulb really and they all seem to be fine.
I will however check the condition of the sockets to see if that will rectify the fault. Might even chuck in all new globes for good measure.
Thanks for your help. Smile I'll let ya's know the result.
Matt
Bobski
Re: MA70 Tail Light Warning, I think Mon, 11 October 2004 14:21 Go to previous messageGo to next message
um..i dont know if this helps or if u mean the same symbol as me, but my bro has a ma70 with digi dash and the light means ur brake pads are running low i think.....cos it started when the wear indicators started making noise and even after changing the pads light stayed on till got toyota guys to reset it
im not quiet sure though was a while ago and he dealt with it not me....ill ask him next time i see him
Adam
Maphril
Re: MA70 Tail Light Warning, I think Wed, 13 October 2004 15:17 Go to previous messageGo to next message
Hmmm, that's also quite interesting, but it still doesn't help that both sets of warning light came on at the same time. Like when it was intermitent I could press the brake and both sets came on. That's why I thought they stood for the same thing (the tail lights). I'll investigate the brake as well. Thanks for your help.
Bobski
Re: MA70 Tail Light Warning, I think Wed, 13 October 2004 16:34 Go to previous messageGo to next message
well actually...since last time i spoke to my bro he said it was the suspention..cos they came back after he had em reset....we just put teins in and he said the warnings went off... so who knows....good luck...and tell me what it is after u figure it out
Adam
Maphril
Re: MA70 Tail Light Warning, I think Fri, 15 October 2004 02:47 Go to previous messageGo to next message
The rear does "hoot" like I've run over an owl or something along those lines. I've oiled the shock shafts and it's reduced it a bit since then.
NopartsTim
Darwin
Re: MA70 Tail Light Warning, I think Fri, 15 October 2004 05:42 Go to previous messageGo to next message
It also lights up if the numberplate lights dont work. Just incase you havent checked them.
Maphril
Re: MA70 Tail Light Warning, I think Fri, 15 October 2004 09:46 Go to previous messageGo to next message
No I haven't checked them. Thanks, I'll check Smile
[Updated on: Fri, 15 October 2004 09:46]
dingaling
tas
Re: MA70 Tail Light Warning, I think Sat, 16 October 2004 07:49 Go to previous messageGo to next message
sure enough, that same warning light has started coming on with my car again. only every now and again. So i'm thinking a dodgy connection with the globe sockets.
I don't think the those warning lights are related to suspension or brake pad wear.
another thing to check is a little black electronic box that can cuase the warning light to go off. It's located near the rear lights. It's unlikey to screw up, but i've heard other people find dry solder joints or moisture getting in and setting off the warning light.
Maphril
Re: MA70 Tail Light Warning, I think Mon, 25 October 2004 05:57 Go to previous message
After sitting round and wasting some time, I finally got around to seeing what the possible cause of all this was and found that water had made it's way into the light failure box. The IC's are corroded and some tracks damaged and I can't get the parts to replace them... sooo, this brings me to my next question,
WHO'S GOT A LIGHT FAILURE BOX???
I'm also advertising in the "parts wanted" as well.
Thanks for your help everyone as well.
Previous Topic:Ordering my 4agze this week. What should I look for?
Next Topic:New clutch for Celica GT4 ST185??
Current Time: Wed Oct 14 12:06:58 UTC 2026
Total time taken to generate the page: 0.15721106529236 seconds
