Toymods » Tech & Conversions » 1ggte + rack and pinion + ra28
matt_84
Ipswich
1ggte + rack and pinion + ra28 Sat, 09 October 2004 07:24 Go to next message
Given the issues with steering box clearance when doing this conversion, I'm guessing stock turbos, plus rack and pinion conversion in an ra28 is a no go?
I'd like to work it out now, as in Joels ra28, he uses a ta23 crossmember, which would be ideal also for a front sump 1g.
gold28
Madrid - Spain
Re: 1ggte + rack and pinion + ra28 Mon, 11 October 2004 12:02 Go to previous message
You shouldn't have any problems with the standard steering box and the 1G. Yes the turbo's do come close but it is easily workable.
If you want to convert to a rack then you will need a T series crossmember otherwise yout rack will be sitting inside your sump.
I am considering a rack conversion for mine. Both for driveability and the better sump arrangement.
Don't underestimate the amount of work involved in getting a rack conversion to work well though. Getting the engine in will be the easy bit.
Previous Topic:O2 Sensor Wires
Next Topic:MZ21 Air suspension q's
Current Time: Sat Oct 24 03:58:40 UTC 2026
Total time taken to generate the page: 0.0063600540161133 seconds
