Toymods » Tech & Conversions » bog in a tube.....seam sealant??
brett_celicacoupe
townsville NQLD
bog in a tube.....seam sealant?? Sat, 09 October 2004 09:37 Go to next message
hi,
have been sandin and sandblasting my car lately back to bare metal and i have noticed many of the seams/joins are sealed by a gluey silicon sorta stuff (silicon cant be painted). i wanna put some new sealant on the seams, but apparently there is a paintable silicon stuff called 'no more gaps' or sumthin. i dont want to use it bcos it promotes rust...waterbased. is there sealant that is like bog that wont promote rust??? bog is a little impractible for this job.
also windscreen sealant, i assume this is okay to use silicon on them, or is there special stuff for that too.
pro_ke
adelaide
Re: bog in a tube.....seam sealant?? Sat, 09 October 2004 10:55 Go to previous messageGo to next message
just go to your local (decent) parts shop and ask for some seam sealant... its not quite silicone and yes you can paint it... ive seen it used on a number of cars from restoring window rubbers to filling up rust holes in the engine bay!
you can get it in grey and black as well
good shit the old seam sealer
brett_celicacoupe
townsville NQLD
Re: bog in a tube.....seam sealant?? Sat, 09 October 2004 11:26 Go to previous messageGo to next message
thanx mate Smile
1 more ques.....should i put it ova the etch primer or on the bare metal??
pro_ke
adelaide
Re: bog in a tube.....seam sealant?? Sat, 09 October 2004 12:16 Go to previous messageGo to next message
thats a good question
id probably put it over the primer then spray a bit of primer over it again just to be sure
chances are i am wrong Wink
YelloRolla
On your mum!
Re: bog in a tube.....seam sealant?? Sat, 09 October 2004 12:23 Go to previous messageGo to next message
It is called drip check and is available from spray paint suppliers. You put it on after the primer - no need to primer over.
brett_celicacoupe
townsville NQLD
Re: bog in a tube.....seam sealant?? Sun, 10 October 2004 03:14 Go to previous messageGo to next message
cheers Smile
TheStitt
Membership Secretary
Re: bog in a tube.....seam sealant?? Mon, 11 October 2004 00:54 Go to previous message
use windscreen selant.
It only goes a "skin" on the outside it remains flexiable on the inside great if the screen ever has to come out again
Previous Topic:Anyone know the details on 2004 Corolla engine
Next Topic:Speedo Cable on GA70?
Current Time: Sat Oct 10 01:43:26 UTC 2026
Total time taken to generate the page: 0.005856990814209 seconds
