Toymods » Tech & Conversions » 3S GTE Air Flow Meter
OviMR2
3S GTE Air Flow Meter Sat, 09 October 2004 11:17 Go to next message
Hey guys..
im having a little trouble with my MR2 3S-GTE choking when i rev it really hard off idle.. If i try to take it easy on the throttle, it revs to about 2000rmp then chokes again.. I have a suspicion this might be the air flow meter.. if so, can any other meters be used in place of my unit??
-==L=a=N=c=E==-
Brisbane, Queensland
Re: 3S GTE Air Flow Meter Sat, 09 October 2004 11:20 Go to previous messageGo to next message
You can only use the GT4/MR2 Airflow meters. Apparently the RX7 series 4 can be used, but not perfect.
I have a spare one if your interested.
[Updated on: Sat, 09 October 2004 11:33]
OviMR2
Re: 3S GTE Air Flow Meter Sat, 09 October 2004 11:32 Go to previous messageGo to next message
serious?? how much you want for it??
I gotta make sure it actualy is my afm tho Confused Ill keep you posted
-==L=a=N=c=E==-
Re: 3S GTE Air Flow Meter Sat, 09 October 2004 11:36 Go to previous messageGo to next message
OviMR2 wrote on Sat, 09 October 2004 21:32
I Don't know yet, see how you go. Check your diagnostic codes.
OviMR2
Re: 3S GTE Air Flow Meter Sat, 09 October 2004 11:40 Go to previous messageGo to next message
diagnostic codes? how do i find them out.. and what do they mean??
Any info would be great Smile
-==L=a=N=c=E==-
Re: 3S GTE Air Flow Meter Sat, 09 October 2004 11:44 Go to previous messageGo to next message
Alright, it 'should' be the same as the GT4.
Have a look in your engine bay, and find the diagnostic port. Once you have, short out the T and the E1 connections. Now go and turn you car to 'ON' but don't start the car. If there are no codes, it will flash steadily. If there are codes, take down the pulses, and there values.
EDIT: the Check Engine light will flash....
[Updated on: Sat, 09 October 2004 11:46]
jase
Re: 3S GTE Air Flow Meter Sun, 10 October 2004 14:34 Go to previous message
OviMR2 wrote on Sat, 09 October 2004 21:17
Hey guys..
That sounds more like a small spilt in the inlet pipe that goes between the front of the turbo to the afm, and when the motor "rocks" the split is being opened.
Previous Topic:toyota 2000 twin cam 16 valves Tvis 3sge i need info
Next Topic:4agte in a ke35
Current Time: Fri Nov 20 21:22:23 UTC 2026
Total time taken to generate the page: 0.006633996963501 seconds
