Toymods » Tech & Conversions » URGENT : ST165 - need quick fix
RWDboy
URGENT : ST165 - need quick fix Sat, 09 October 2004 13:28 Go to next message
Hey, I need to get the electric fans to operate continuously as it seems that they aren't getting a good signal (yes i know that this isn't the best solution, I just need a really quick temporary fix so I can get the damn thing home tomorrow). What's the easy way? Does the ECU ground it out or something, which wire would I cut/disconnect to get them to permanently run? Or do I have to get down near that water junction near the dizzy and disconnect something there?
[Updated on: Sun, 10 October 2004 03:53]
SXY184
Re: ST165 - need quick advice Sat, 09 October 2004 23:48 Go to previous messageGo to next message
, hey , why dont ya just unplug the connector plug to the fans,and connect a wire from the battery to the plug for the fans, that will work ,or am i wrong , ?
SXY184
RWDboy
Re: ST165 - need quick advice Sun, 10 October 2004 03:52 Go to previous messageGo to next message
Cause that would involve buying a piece of wire Smile
RWDboy
Re: ST165 - need quick advice Sun, 10 October 2004 03:53 Go to previous messageGo to next message
btw I need this information within two hours please!
dingaling
tas
Re: ST165 - need quick advice Sun, 10 October 2004 07:21 Go to previous messageGo to next message
THE SIMPLE WAY! FIND YOUR WATER PUMP, THERE IS A THERMO SWITCH THERE, UNPLUG THE WIRE GOING TO THAT AND YOUR FANS WILL SPIN UNTIL YOU PLUG IT BACK IN, OR TURN YOUR CAR OFF.
SORRY FOR THE CAPS.
RWDboy
Re: URGENT : ST165 - need quick fix Sun, 10 October 2004 15:05 Go to previous message
CHEERS - IT'S A LITTLE LATE BUT THAT'S BASICALLY WHAT I DID, CURRENT DIAGNOSIS IS THAT THE RADIATOR IS PARTIALLY BLOCKED AND THE THERMOSTAT IS METRO.
Apology accepted Wink
Previous Topic:Here we go again - 4AGZE pulley
Next Topic:engine parameter calculator
Current Time: Sat Nov 21 22:13:56 UTC 2026
Total time taken to generate the page: 0.0094358921051025 seconds
