Toymods » Tech & Conversions » MZ21 Air suspension q's
TurbOwen
Wollongong
MZ21 Air suspension q's Sat, 09 October 2004 21:10 Go to next message
I am buying an MZ21 gt limited with air susp. Do i need to lock or disable the system to jack the car up off the wheels? I know this is a requirement on other cars with air struts. If so how do I do it.
Also does anyone know where I can find an english conversion of the controls in the car?
waxE
Perth, WA
Re: MZ21 Air suspension q's Sun, 10 October 2004 03:39 Go to previous messageGo to next message
theres a button above ur auto lever, that should say tems hi/lo or summin, push it and ur car will magically raise up n down.
alternativly, if its on your wheels and u cant move them, u prolly need new suspension, either ur bags, pump or computer have failed.. idecided not to fix it and install some teins.. best thing i have done!
also if ur car goes up n down normally but ur car is to low, check underneath ur car just left of the rear right wheel, there is a rod with a screw in it, simply adjust it and ur car goes up n down, same for the front but on both sides..
hope this helps
TurbOwen
Wollongong
Re: MZ21 Air suspension q's Sun, 10 October 2004 04:29 Go to previous messageGo to next message
thanks but thats not what i meant, to jack the car up in the air, ie to change tyres brakes etc is there any procedure i need to go through first to stop the air bags popping when they are hanging?
TurbOwen
Wollongong
Re: MZ21 Air suspension q's Sun, 10 October 2004 05:10 Go to previous messageGo to next message
bugger! just bought the cartoday and the tems was all working and then after 45min on the way home the check tems light came on and the system wont adjust itself. its not sinking, just wont do anything. the cars got an aftermarket height adjuster and it doesnt seem to do anything either. how do I check what code is bringing this light on? surely someone must know how to extract and clear codes? I cant even jack it up safely yet to check the sensors underneath. it doesnt sound like the pump is working either and it definatly was a few hours ago!
TurbOwen
Wollongong
Re: MZ21 Air suspension q's Mon, 11 October 2004 11:54 Go to previous message
Fixed the fault code and all is well again! still need to know the proper way to lock the bags to jack the car up. Pulling the fuse looks a goer at the moment.
Previous Topic:1ggte + rack and pinion + ra28
Next Topic:RWD 4age exhaust
Current Time: Fri Oct 23 10:09:27 UTC 2026
Total time taken to generate the page: 0.004647970199585 seconds
