Toymods » Tech & Conversions » 1G-GTE CT12 upgrade?
Silent_AW10
Wellington, NZ
1G-GTE CT12 upgrade? Sun, 10 October 2004 02:57 Go to next message
Just wondering if the CT20 will bolt onto the CT12 manifold? or what other turbo will bolt onto the CT12 manifold of my 1g-gte? i figured since the compressor wheel blew off one of the turbs i should just upgrade them rather than fix them....
otherwise, how do i go about fixing the stuffed compressor wheel? and what do i need to replace to stop the oil leaks? i can't be bothered having them reconditioned, so if i can fix them with a new wheel and gaskets i will just upgrade them with something, but what?
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
Re: 1G-GTE CT12 upgrade? Sun, 10 October 2004 04:55 Go to previous messageGo to next message
Just buy a pair of 2nd hand CT12As and put them in.
Cheaper and less hassle.
Silent_AW10
Wellington, NZ
Re: 1G-GTE CT12 upgrade? Sun, 10 October 2004 08:18 Go to previous messageGo to next message
ok, i will try. I can get CT20's for $75 each from a wrecker. Also i just found out that the HG has decided to part with me, so whats involved on doing a HG on the 1g-gte? is there anything else that i should replace while head is off?
Re: 1G-GTE CT12 upgrade? Sun, 10 October 2004 08:46 Go to previous messageGo to next message
Nark wrote on Sun, 10 October 2004 14:55
are you sure?
the dump pipe flange and possibly the exhaust manifold flange appear to be different:
<http://www.toymods.org.au/1G_vs_1JZ/>
before buying two used CT20's -i'd check that they'll actually bolt up (e.g. right flanges) and that your budget also allows for new/other dump pipes and possibly manifold as well.
... i dunno about HG - but my limited experience with alloy-head motors is that you may have to have repair (welding) work done on the head if there is corrosion between water jacket and elsewhere. But if it;'s just the gasket, then probably doing nothing apart form cleaning valve-faces up would probably suffice.
As per recent threads about 1G performance upgrades, there's a lot more to be gained from upgrades outside the engine (turbo, exhaut, computer, injectors, etc)
Nark
Cabramatta, NSW
Re: 1G-GTE CT12 upgrade? Sun, 10 October 2004 10:24 Go to previous messageGo to next message
Oops! Sorry, for some reason, my brain stopped working and I thought the 1Gs has CT12As...
No, they're not going to fit.
Siktoy ra23
Plumpton/sydney
Re: 1G-GTE CT12 upgrade? Sun, 10 October 2004 10:30 Go to previous message
You could but my ct12 turbos of me Very Happy
Previous Topic:HELP !
Next Topic:4age smallport rwd exhaust manifold options
Current Time: Sat Oct 17 07:06:50 UTC 2026
Total time taken to generate the page: 0.0047540664672852 seconds
