Toymods » Tech & Conversions » 2T timing mark
greenta22
Dandenong Ranges, VIC
2T timing mark Sun, 10 October 2004 05:13 Go to next message
which is the correct ignition timing mark on a 2T? ive got one on the front of the crank pulley (radiator side), which is arrow shaped, and a rectangular groove cut into the back of the pulley (block side.) spose i should just pull the rocker cover off and check what the the valves are doing. let me know anyway if you know...
fade-e
Re: 2T timing mark Sun, 10 October 2004 05:41 Go to previous messageGo to next message
i got 2 and both mine is on the block side... my motor wsa rebuilt a long time ago and from the rebuild the timing went off a bit and therefore the timing mark was re adjusted. seems like that may have been the same for you, a motor rebuild
both my marks are like 3mm apart so i just put it in the middle for my motor... what you can try is adjust toiming to first mark and check motor and then use other mark and whoch ever is better idle is the one you use
greenta22
Re: 2T timing mark Sun, 10 October 2004 07:58 Go to previous message
the trouble is mine are about 10cm apart. think i know which one it is though, was near enough when both valves were close on cyl 1. i guess i'll work from there.
thanks.
Previous Topic:Price to rebuild 3SGTE g/box?
Next Topic:KE35 whats an easy fit?
Current Time: Thu Oct 15 11:03:09 UTC 2026
Total time taken to generate the page: 0.0036280155181885 seconds
