Toymods » Tech & Conversions » mhg/o-ring dilemma
Jayem
Finland
mhg/o-ring dilemma Sun, 10 October 2004 11:10 Go to next message
I tried to search but didn't find anything useful regarding to o-ring design or dimensions. My plan is to use copper head gasket and o-rings. Look the cross section pic I made. Does the design or the dimensions look anything right.
http://toyotacover.50megs.com/sekalaiset/Copperheadgasketandoring.jpg
The red part is the o-ring.
Yellow part is the head gasket.
Rest (white) is the block.
The plan is to machine 2mm deep, 3mm wide groove in the block and o-ring will be 2.98mm thick. This 2.98mm is based on assumption that the copper sheet will be 1.00mm thick. Head deck surface will be plain. I can cut the head gasket by laser and I have already made cad drawing of the HG. Once the annealed(correct word?) copper head gasket is assembled it will be compressed 0.02mm and o-rings will seal the combustion chambers. Would this work???
here's the cad drawing of the design. Change it the way you see better!
http://toyotacover.50megs.com/sekalaiset/liekki rengas.dwg
allencr
tallahassee FL usOFa
Re: mhg/o-ring dilemma Sun, 10 October 2004 13:36 Go to previous messageGo to next message
o-ring material?
Ra28Freak
Brisbane CBD
Re: mhg/o-ring dilemma Sun, 10 October 2004 15:12 Go to previous messageGo to next message
i always thought that you left a mm or 2 from the edge of the bore it is used to clamp the copper better aroudn the bore diameter? true or false
shinybluesteel
melbourne
Re: mhg/o-ring dilemma Mon, 11 October 2004 07:44 Go to previous messageGo to next message
i concur,
what little i have seen of o-ringing, the ring groove is concentric to the cylinder bore, but out a bit from the edge.
i'd get an engine builder to o ring it.
[Updated on: Mon, 11 October 2004 07:45]
ed_ma61
Lost in the K hole
Re: mhg/o-ring dilemma Mon, 11 October 2004 08:12 Go to previous messageGo to next message
i wrote a big reply to this last night, then accidentally deeted it No No No
in short - what youve drawn is a recessed fire ring. normally fire rings are neither recessed, nor used with copper gaskets.
what you want is a recessed ring, a few mm from the bore edge, that just protrudes from the block surface, and sits UNDER the copper material to provide a circumfrential ring of increased clamping pressure... thus holding the soft copper in place against combustion pressure.
ed
Jayem
Finland
Re: mhg/o-ring dilemma Mon, 11 October 2004 10:42 Go to previous messageGo to next message
Anything like this?
http://toyotacover.50megs.com/sekalaiset/Liekkirengas%203.jpg
I dont like this design. Crying or Very Sad
First one was better IMHO, with fire ring bit out from the edge as suggested and maybe bit more clamp to the HG.
Few points that I forgot to mention earlier:
Engine will be turbo charged.
Oil goes into head through external pipe.
Water channel can be O-ringed too with rubber O-Rings.
I have seen several o-ring approaches. But they all have been made by some sledge smiths. I just haven't seen proper one.
Thanks in advance...
Ra28Freak
Brisbane CBD
Re: mhg/o-ring dilemma Mon, 11 October 2004 11:59 Go to previous messageGo to next message
just go for a grove not a recess the wire will fall right in the bore like that
Jayem
Finland
Re: mhg/o-ring dilemma Mon, 11 October 2004 12:45 Go to previous message
Wire?
I'm thinking solid steel ring.
But yeah I get your point.
Previous Topic:GZ20 diagnostic??
Next Topic:im sellin extractors....whats a good price????
Current Time: Sat Oct 24 08:29:56 UTC 2026
Total time taken to generate the page: 0.0086019039154053 seconds
