Toymods » Tech & Conversions » E282 DIFF ?
alex_ta22
Newcastle, Hunter Valley
E282 DIFF ? Mon, 11 October 2004 07:58 Go to next message
Are these E282 diffs good for anything like conversions ? (from toyota vans)
alex_ta22
Re: E282 DIFF ? Mon, 11 October 2004 08:06 Go to previous messageGo to next message
They are roughly the same width tire to tire as the TA22, also have the same stud pattern
Lambolica
Northwestern Sydney
Re: E282 DIFF ? Mon, 11 October 2004 08:17 Go to previous messageGo to next message
They are just a little bigger than a T series diff, I would guess hard to find gears for as well.
You'd be better to find a F series out of an MX23 which will be close as well.
alex_ta22
Re: E282 DIFF ? Mon, 11 October 2004 08:29 Go to previous messageGo to next message
Do you know if they are good for any other application? (are they sought after for anything)
Lambolica
Northwestern Sydney
Re: E282 DIFF ? Mon, 11 October 2004 08:36 Go to previous messageGo to next message
Not that I'm aware of... unless you have a Liteace van.
As far as wanting to put it in a TA/RA celica, it wouldn't be worth the trouble..
Jonny2TG
Tasmania
Re: E282 DIFF ? Mon, 11 October 2004 09:21 Go to previous messageGo to next message
The main issue is, can you get a LSD for a E series diff? Not that I know of. People needing a big diff in a Celica/Corolla often jump to the G series HiLux diff, with LSD.
gold28
Madrid - Spain
Re: E282 DIFF ? Mon, 11 October 2004 11:37 Go to previous messageGo to next message
They are a small step up from a T series and thats about it. I put one in my 28 by accident and it has put up with 150rwkw fine. I have done a little drag racing on street tyres with it and had no problem. A day at wakefield and it is screaming though. But then again I would have killed any open centre that day.
If your planning an upgrade, I wouldn't bother with an E series. Unless you looking at a fairly powerful engine, I would use a Ta22 T-series diff and find a sprinter LSD for it. Otherwise you will need to find a fairly narrow/stronger diff or get one cut down. The 22's are pretty narrow in the bum.
alex_ta22
Re: E282 DIFF ? Mon, 11 October 2004 12:17 Go to previous messageGo to next message
so they are are straight bolt in for the ta22, ra23 and ra28?
gold28
Madrid - Spain
Re: E282 DIFF ? Thu, 14 October 2004 09:34 Go to previous message
Nup, gatta cut all the old mounts off, fabricate some new ones to fit the celica and weld them on.
When I get hold of an F series, I will be doing the same with that. They are stronger again than the E series and have a good selection of LSD's available.
There is no easy upgrade that I am aware of, so unless you are handy with an angle grinder and welder, it's gonna cost you some cash. I think the early 22's had a smaller diff than the later ones. Check your compliance plate for a transaxle code and it should tell you what type of diff is in it.
Previous Topic:Max RPM on CT12's
Next Topic:ac on a 18rg
Current Time: Sun Oct 25 00:40:46 UTC 2026
Total time taken to generate the page: 0.0043900012969971 seconds
