Toymods » Tech & Conversions » MORE HP FOR MY 2T
juzzo84
Hornsby, N.S.W
icon12.gif  MORE HP FOR MY 2T Sun, 29 September 2002 11:52 Go to next message
im currently running my 2t ta22 with a ramflow filter,genie extractors and 2 inch exhaust system, by porting and polishing the head, am i able to get more out of the girl?
juzzo
juzzo84@hotmail.com
Kiwi Jake
Narellan
Re: MORE HP FOR MY 2T Sun, 29 September 2002 11:57 Go to previous messageGo to next message
Every little bit counts. Try sourcing a 2TG twin cam head (probably wouldn't cost much more, if any, than a good port job and head recon.) They bolt straight on all you have to do is source the chain guides for the overhead cams.
Re: MORE HP FOR MY 2T Sun, 29 September 2002 23:13 Go to previous messageGo to next message
It's not quite that easy - you'll also need 2T-G pistons and the idler shaft to replace the OHV camshaft. Much easier replacing the whole engine with a complete 2T-G. Note that you will be able to keep your extractors and exhaust system as the exhaust manifold has the same bolt pattern.
Re: MORE HP FOR MY 2T Mon, 30 September 2002 04:49 Go to previous messageGo to next message
justin. check out the trading post from last thurs, or better yet do it online... there was a few 2t-g's in there!
i did a search for celica with price range 0-6000 and found 2 or 3 2t-g engines while i was looking for a celica this week.
Pumpkin
Toymods Board Member
Re: MORE HP FOR MY 2T Mon, 30 September 2002 07:09 Go to previous messageGo to next message
Juzzo..
A good port and polish will improve.. but not much.. Being a downdraught carbie... Your better off changing the intake system altgether with a good flowing side draught.. You can port the head all you like, but it will still only flow as good as your worst runner on your manifold..
I had a 2T with a dell orto carbie hanging of the side on a lynx manifold.. (i think i still have it).. It was well out of tune.. but made 42 KW at the wheels.. Just to compare.. I now have a 2TGEU and that makes 47KW.. Not far off!!! Rolling Eyes
You can do more to a 2TG and you also have the added revability.. But well tuned 2T will be up there alongside.. Very Happy
[Updated on: Mon, 30 September 2002 07:16]
Re: MORE HP FOR MY 2T Mon, 30 September 2002 07:41 Go to previous messageGo to next message
It's true that you can modify a 2T to make pretty decent power, but 2T-G's are cheap and piss-easy to install. Modifying a 2T simply isn't as cost effective.
Pumpkin
Re: MORE HP FOR MY 2T Mon, 30 September 2002 09:59 Go to previous messageGo to next message
Totally agree... Just for a intake setup on the 2T, will cost you $800-$1000 by the time you get it tuned. For that money you can have a 2TG..
Juzzo.. up to you. I have the intake manifold and know of someone that would probably part with the dell orto.. If you want to keep the 2T.. That would probably be your easiest gain of any power.. The standard 2T carbie choke at 4000rpm at dont like to go above that..
If not upgrade to a 2TG, and have more to play with..
Unfortunatly I have not kept to the original question.. Sorry. But it gives you something to think about..
Grega
melbourne.victoria.austra...
Re: MORE HP FOR MY 2T Mon, 30 September 2002 10:40 Go to previous messageGo to next message
there are a few different varieties of cams too for the 2T/3T
i have a friend - his son has a ke20 with a 3T/2T combo with twin webers making 200hp!
so there is plenty of potential. my ta22 has paceys, 2" zorst and a free flow air filter too - goes well for what it is..
Re: MORE HP FOR MY 2T Mon, 30 September 2002 11:50 Go to previous messageGo to next message
No-one said the 2T doesn't have potential, just that it costs a lot of money to extract that potential. I can guarantee this 200hp 2T cost a whole lot more than a 2T-G swap!
Re: MORE HP FOR MY 2T Mon, 30 September 2002 12:12 Go to previous messageGo to next message
I have a 2T sitting here thats just recently be rebuilt! Its got a webber sitting on the stock manifold using an adaptor plate! Would getting a good manifold improve breathing at all?
Pumpkin
Re: MORE HP FOR MY 2T Mon, 30 September 2002 22:30 Go to previous messageGo to next message
From what I have seen, Toyota have there intake manifolds about as free flowing as they can.. Your option would be to change to a side draught setup.. Side draughts should outflow down draught everytime, due to the bends..
But, yes, a good manifold will increase air flow.
As long as you have a good set of extractors to match..
Grega
Re: MORE HP FOR MY 2T Tue, 01 October 2002 00:39 Go to previous messageGo to next message
agreed norbie - 2T is not cost affective in power gains. unless you can do it on the cheap - really depends which way u wanna go
Re: MORE HP FOR MY 2T Tue, 01 October 2002 08:20 Go to previous messageGo to next message
The reason I asked about the manifold is because I dont want to get rid of the webber! I want to fit this engine in the girlfriends car when she gets one! So it will be getting a set of extractors aswell!
Any idea where I could get a manifold to suit the job?
thetoyman75
Club President
Re: MORE HP FOR MY 2T Tue, 01 October 2002 10:33 Go to previous messageGo to next message
Juzzo,
Mate how much do you really want to spend ? If the answer is bugger all then the only cheap mod you appear to be missing is fitting a Downdraft weber to the stock manifold using an Adaptor plate. The 32/36 downdraft weber will bolt up and should set you back $30-$50 tops (2 litre Ford escort/Cortina) Ataptor plate was $30 last I bought one (Looooong time ago !)
Port and polish will cost you a few dollars and will only give you gains as far as the rest of your setup can handle.
The Downdraft weber is by no means a high performance carby but it is better than the stock one.
Your best bet if you want to spend the money is a side draft Carby set up. A single 45mm Side draft weber or delorto will suit all but the most full on 2T engine. However to buy that new is big dollars. A side draft weber new is around $700 these days and the manifold will set you back about $150. Then you need the linkage kit and airfilter plus the dyno time and dizzy graph. So yeah for about $1200 - $1500 you can re-carby the 2T quite nicely.
Cool 1,
No downdraft manifold and carby setup will match the performance of the equivalent Side draft version. Side draft is quite simply just better (Less restrictive)
Grega,
200 HP 3T/2T hybrid ?? Mate that is a pretty big claim. What sort of Fuel and compression is it running. ? Also where is that power figure from and what sort of Dyno was it. The 2T is a Cross flow Hemi head so does respond well to big dollars.
Keeping in mind that the BEST power acheived from a 2TG in FULL RACE SPEC is 200 HP i would be very amazed to see a 2T acheive it. Not saying it isn't possible just well above any I have heard of. Best I know of was in the 170 - 180 HP bracket. See if you can get it to the Dyno day. Be great to see a 2T take home the trophy Smile (assuming he became a member)
justinharwoodran
Re: MORE HP FOR MY 2T Wed, 02 October 2002 06:19 Go to previous messageGo to next message
Well I just chromed the stock 2T air cleaner and rocker cover, added a new fuel filter, a new battery, sand blasted the headers, painted them and added a heap of new stainless hex bolts here and there and I swear it added 100hp. Maybe with a new fan belt and a drop of good oil she'll be putting out more hp than the new lawn mower. Fingers crossed, I'll keep you posted with pics coming soon.
Justin
ps if she don't go, she might as well look nice till she does.
justinharwoodran
sorry dunno what happened here
[Updated on: Wed, 02 October 2002 06:20]
Sammeh
Re: MORE HP FOR MY 2T Wed, 02 October 2002 17:22 Go to previous messageGo to next message
I have a 2T with a sidedraft 45mm DCOE Weber which shits all over the stock setup. The guys who installed it though really didn't know what they are doing and i haven't Dyno'd it yet, will be doing that when i rip off the RamFlo air filter to replace it with a K&N filter.
Hopefully i'll have some figures up here soon of what kinda kW's it is putting out, torque etc..
So now i need to know.. what more can i do to squueze more juice out of her? what's this about port and polishing? i'm kinda illiterate when it comes to engine mods so a brief explainasion would be appreciated.
Sam
Grega
Re: MORE HP FOR MY 2T Wed, 02 October 2002 21:51 Go to previous messageGo to next message
hey rod.....how r u dude? i'll send you an email with some stuff about this.
the head has had MASSIVE amounts of work done to it $$$$ is no issue (his dad runs a reputable head place here in melb)- am a little sketchy on the details of what else has been done to it - ie: bottom end ect - might be able to find out - that said it runs a pair of DCOE45's which have been jetted to suit. fuel will more than likely be PULP, compression ratio will be up there.
prolly better if i send you the article methinks.
its a sports sedan - motors fitted in a ke20 coupe full race kit pretty grouse. tho from what his dad tells me the motor is coming out for a 3sge replacement.
hey sam if the dudes who set it up didn't know what they're doing make sure u take it and get it jetted to suit dude. then get it dynoed!
[Updated on: Wed, 02 October 2002 21:52]
thetoyman75
Club President
Re: MORE HP FOR MY 2T Thu, 03 October 2002 01:31 Go to previous messageGo to next message
Grega,
Sounds like he has the perfect backing. Head work can deffinatly make all the difference. I'll look forward to you email Smile
Whilst on the topic of T series engine. The Toymods under 1800cc Quater mile record was squashed last night but a 3TGTE. 12.1 from Yellorolla. Offical results to go up soon Smile
Grega
Re: MORE HP FOR MY 2T Thu, 03 October 2002 07:39 Go to previous messageGo to next message
rod i've sent the email to your toymods address. the files are pretty darn big - three seperate emails dude.
Classique71
Colac, Victoria
Re: MORE HP FOR MY 2T Thu, 03 October 2002 09:45 Go to previous messageGo to next message
Havoc wrote on Mon, 30 September 2002 17:09
Juzzo..
LOL _ irony strikes - mine made exactly that figure in its shitty tuned form recently - with all the right stuff bar cam ( sidedraft weber , extractors , headwork , forgies etc etc
Took it to a guru with my NEW CAM ! and he expects somewhere between 85 - 120 HP at the rears - which is a shit load more KW than before ..
mind u its getitng a 3/4 race cam slotted in it that was tested and documented to produce over 180 HP at the flywheel
as for revving - mine will rev out to 6800 without complaint atm , so they aint that far behinds a 2tg
celicamad85
Banned member
Re: MORE HP FOR MY 2T Thu, 03 October 2002 09:51 Go to previous messageGo to next message
a stock 2tg revs to 7500rpm safely and thats without needing to upgrade valve springs Cool
EMP-2TG
Carlingford, Sydney
Re: MORE HP FOR MY 2T Thu, 03 October 2002 10:57 Go to previous messageGo to next message
my 2tg made 52kw at the last dyno day in a rather bad state of tune (totaly stock motor)
dunno y i said that but Smile
Classique71
Colac, Victoria
Re: MORE HP FOR MY 2T Thu, 03 October 2002 11:04 Go to previous messageGo to next message
theres bugger all in it between a 2tb and a 2tg bar about 5 horsepower or so - and around an extra 500 RPM squeezability from a 2tg ..
i guess its in Modified form where the real differences show - 2tg in theory should rev harder , but smoother - than the 2t by far - though a good 2t will still perform very well when modified also ..
Overall theres a bee's whisker in it overall IMHO..
just one costs alot cheaper to make for bang for bucks Smile
thetoyman75
Club President
Re: MORE HP FOR MY 2T Thu, 03 October 2002 23:50 Go to previous messageGo to next message
Grega,
Thanks for the article, looks like a neat little KE20. Can you find out for me if it is indeed the stock 2T crank as stated or a 3T crank as infered by the listed capacity ?
Classique 71,
Biggest difference between a full house 2T and a Full House 2TG will be the Low RPM responce and Idle. A 2T only has a single cam and will get quite a big rhythm up. The 2TG on the other hand will have its two cams helping to balance each other out as they swing around Smile I was under the impression that a N/A 2T was only good for 185/190 HP but there is always new developments and room for improvement if you know how to find it. !
As for build costs... Bugger all difference. They basically need the same components anyway !
Josh,
Tina's Celica made the quarter Mile record for its class with only 61 RWKW so get yourself some soft rubber, Maybe a locked diff and see how you go ! Last Dyno day we managed 76 KW out of it and that was as driven daily. Still with cast pistons and very streetable cams !. There was alot more potential left in it !
Celicamad 85,
Its not just the RPM but the lift that the springs need to cope with. Stock items are not a bad unit tho Smile
[Updated on: Thu, 03 October 2002 23:55]
EMP-2TG
Carlingford, Sydney
Re: MORE HP FOR MY 2T Fri, 04 October 2002 05:29 Go to previous messageGo to next message
yeah i think ill have to (after the next dyno day)
im aiming for mid 60kw i get everything done by then
so we shall see Smile
Grega
Re: MORE HP FOR MY 2T Fri, 04 October 2002 09:16 Go to previous message
rod i will find out what i can dude.
Previous Topic:engineer cert transfer
Next Topic:Gearbox conversion
Current Time: Sun Oct 18 22:57:54 UTC 2026
Total time taken to generate the page: 0.0055930614471436 seconds
