Toymods » Tech & Conversions » Solex not squirting
SIKTA22
Solex not squirting Tue, 12 October 2004 01:10 Go to next message
Im trying to revive my older phh solexs at the moment and im stuck on one carb, to test i put fuel in it and pump the throttle until fuel squirts out of both sides, my other solex carb works perfectly when doing this but i dont know why my other one doesnt.. any ideas?
thanks.
bbaacchhyy
Re: Solex not squirting Tue, 12 October 2004 01:12 Go to previous messageGo to next message
The accelerator pump diapraghm is probably stuffed. Depending onm how long they have been sitting around, you may need overhaul kits to make sure they don't leak when on the car.
Michael B
SIKTA22
Re: Solex not squirting Tue, 12 October 2004 01:23 Go to previous messageGo to next message
thanks for the quick reply mate, but my diaphrams are in good shape as i had pulled it all apart and put it back together again, the actual pump works because i can feel air being forced out the little hole but when i stick it on the carb with some fuel in there it just doesnt want to pump fuel.. its very strange..
OLD-12C
Re: Solex not squirting Tue, 12 October 2004 09:54 Go to previous message
when you take off the bottom diaphram there should be a little plug with a spring and ball bearing in it
sometimes these pop out when there is a pressure build up thus resulting in no fuel being squirted
also a fine pin comes in handy to clean out all the holes
pull the whole carbies apart and clean them out thoroughly and you will find that will help alot too
also there is two little tubes near the top housing (you will be able too see them when you take the top off) they also have little ball bearings in it be sure to check that they are still in position
any more questions drop me a line
Previous Topic:Ta22 GT vs LT
Next Topic:ma61 sunroof seal
Current Time: Fri Oct 16 10:53:27 UTC 2026
Total time taken to generate the page: 0.043182849884033 seconds
