Toymods » Tech & Conversions » If you had a stock Celica ST162
alliance_22
If you had a stock Celica ST162 Tue, 12 October 2004 03:39 Go to next message
If you had a stock Celica ST162 what would be your list of mods?
I'd be interested to see what the First mods would be.
Very Happy
RWDboy
Re: If you had a stock Celica ST162 Tue, 12 October 2004 04:37 Go to previous messageGo to next message
do a search
dingaling
tas
Re: If you had a stock Celica ST162 Tue, 12 October 2004 13:54 Go to previous messageGo to next message
first thing i'd do is get good looking rims, makes the 162 celica look 10 years newer. and probably an upgraded sound system.
then i'd probably leave it at that Razz
I wouldn't bother with Air intake, extractors becuase honestly your throwing money down the drain, Toyota designed it just fine the first time. If you want noticable power upgrades then your looking at an engine swap (3sge gen2, gen2, 3s-gte etc) or expensive engine stuff like head porting, larger valves, cams, larger pistons, lightened flywheel. the list goes on the $$ add up.
sorry to break it to you Sad
sleeker162
Re: If you had a stock Celica ST162 Tue, 12 October 2004 13:58 Go to previous messageGo to next message
fluffy dice
TRD-ST162
Re: If you had a stock Celica ST162 Tue, 12 October 2004 15:02 Go to previous messageGo to next message
Hmmmm depends what ur after....
They got a bit of potential from a few mods...
I had a stock st162 but wanted something with a bit more balanced power response, extractors and exhaust are pretty decent NA mods... I think the stocky piping is 1.75" or 2", a increase to 2.25" would help a bit, lower down and it will rev cleaner.
The st162 has a fair decent amount of power stock so i'd be concentrating more on suspension and brakes... I have put king springs firmer rate spring, which have a nice amount of movement in the suspension, mistake with lowering cars is the fact that people try and lower their car in hope to stop bodyroll, the springs shouldn't have to stop bodyroll, its in the duty of the sway bar in which body movement is controlled.
Even on dead springs and shocks the rear sway bar will reduce body roll by a fair bit...
I'm pretty happy with performance at the moment after doin a k&n panel filter which helped a tiny bit but got it due to the fact that its reusable and helps the engine breathe a bit better...
Next thing on my list is gonna be to fix up the stereo and make her into a bit more of a cruiser for the summer, eg.. tinted windows, upgrade brakes.....
They do alright with a few mods
Later on the track she'll receive the exhaust, extractors and eventually a nice set of cams....
BROOM!!!!
dingaling
tas
Re: If you had a stock Celica ST162 Wed, 13 October 2004 02:19 Go to previous messageGo to next message
"I think the stocky piping is 1.75" or 2", a increase to 2.25" would help a bit, lower down and it will rev cleaner."
I dunno about that man, your reducing your backpressure by doing that, and will lose power down low but will gain it up top.
Adding a better air filter would allow air to be sucked in easier, but the airflow meter is still the same, so gains would be minimal.
using top quality premium unleaded will probably see your most noticable power gains, as the ECU advances the timing.
RWDboy
Re: If you had a stock Celica ST162 Wed, 13 October 2004 03:27 Go to previous messageGo to next message
Sorry, the ECU won't advance the timing, last I checked they don't have any form of knock sensor to notice the difference in fuel octane.
RobST162
Re: If you had a stock Celica ST162 Wed, 13 October 2004 03:33 Go to previous messageGo to next message
however a JDM ECU which is mapped differently should be a nice "plug n play" power upgrade for not too much dosh
has anyone actually done this?
zorst + intake will free up your top end heaps
if you can't get JDM ECU try advancing your timing a few degrees, running premium and listen carefully to make sure it ain't knocking and you will get a little kick too.
I also HIGHLY recommend a Oil-Catch can. older motor, valve-less crankcase ventalation = good cause for one
acreese
Re: If you had a stock Celica ST162 Wed, 13 October 2004 08:49 Go to previous messageGo to next message
Adjust your AFM, Run 98 Octane fuel and give your dizzy a twist.
I did this and power gain was noticeable and car revved harder.
Probably could get away without AFM mod, some ppl say it does nothing, just costs more fuel.
Yes it does use more fuel, but not much, and you can on 98 octane advance timing to about 16 degrees BTDC. Pulls harder mid range, and doesnt seem to choke from 5500rpm onwards.
Oh and it costs $0 and 15 minutes time,
cheers,
Adam
RWDboy
Re: If you had a stock Celica ST162 Wed, 13 October 2004 09:16 Go to previous messageGo to next message
Technically if you wanted to gain power you'd adjust your AFM to think it was getting less air (stiffer) - thus running leaner, and technically costing less in fuel.
Risks are associated with that though.
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: If you had a stock Celica ST162 Wed, 13 October 2004 09:53 Go to previous messageGo to next message
As much as I soooo wouldn't bother with an st162, if I were enthusiastic about one, I would do the following:
Engine:
4 into 1 extractors, 1.75" primaries into 2.5" collector
2.5" 'cat-back' exhaust system (with free flowing cat)
piss off the AFM and install Megasquirt...
288deg camshafts
clean up castings in the head and port match.
blah blah airfillet o fish and some cold air on the side.
Suspension/Drivetrain/Etc:
TruTrac LSD
Coilovers
4 spot calipers w/vented discs on front
2 spot calipers w/whatever discs on rear
Tune the car to run about 12.5:1 AFR under WOT and heavy load, run about 13~14:1 for lighter loads, and obviously closed loop for crusin Wink
Then for more fun, try and make the bastard lighter.
But then, why would I bother with a fwd car....
buck naked
Re: If you had a stock Celica ST162 Wed, 13 October 2004 17:17 Go to previous messageGo to next message
Do I want to be running the mixture leaner or richer?
I have a pod air filter, does that mean that more air is coming through the AFM causing it to run leaner? I'm happy to run 98 octane fuel, if it will allow me to improve my performance.
Also, is it recommended to reset the ECU before making changes? Where abouts is the fuse you need to pull?
[Updated on: Wed, 13 October 2004 17:27]
Celica_John
Re: If you had a stock Celica ST162 Thu, 14 October 2004 03:39 Go to previous messageGo to next message
buck naked wrote on Thu, 14 October 2004 03:17
in the fuse box Rolling Eyes
in the engine bay. just open the fuse box and it will tell you which one is the efi fuse.
bergerac
Re: If you had a stock Celica ST162 Thu, 14 October 2004 10:37 Go to previous message
If i had an unlimited budget...
- BEAMS 3S-GE out of the ST202
- Suspension mods
- Nice light weight wheels
- Make it as light as possible
- ST165 front bar (sexy)
Previous Topic:TA22 Baby seat mounting
Next Topic:Max RPM on CT12's
Current Time: Sun Oct 25 00:40:34 UTC 2026
Total time taken to generate the page: 0.0064058303833008 seconds
