Toymods » Tech & Conversions » 13BT in KE10
Fatterthanyamumma
ADELAIDE
13BT in KE10 Tue, 12 October 2004 04:58 Go to next message
I would like to hear from someone who has solid advice (even better if from experience) for me in relation to performing this conversion.
I have sighted all the data available on the net and all links from everywhere under the sun.. These have proved to be very useful.
I am just keen to hear from someone (if there is another out there) with solid knowledge and understanding of this proceedure.
I don't want to hear a load of crap, or what the guy who knew the guy that did it and so on.
I will be performing this conversion regardless.. but would be more comfortable knowing I have covered all bases and the in's and out's of doing this.
Cheers and appreciation.
FaTtErThAnYaMuMmA!
pro_ke
adelaide
Re: 13BT in KE10 Tue, 12 October 2004 05:35 Go to previous messageGo to next message
so what exactly do you want to know? its going to be a massive job. have you done anything like this before?
axe performance in sydney have done it, give them a call.
bassy
Re: 13BT in KE10 Tue, 12 October 2004 06:33 Go to previous messageGo to next message
A mate of mine has done it, and i was also considering doing something similar. The thing is the ke10 that was used the firewall has been almost completely removed and the car will be used for hillclimbs etc. I doubt this is going to help you. A lot of custom parts are going to have to be sorted and it is alot of work! However could prove to be very rewarding if done proberly.
pro_ke
adelaide
Re: 13BT in KE10 Tue, 12 October 2004 07:33 Go to previous messageGo to next message
the 1st things that come to mind :
- exhaust clearing steering
- trans tunnel
- shifter position
- radiator/oil cooler size/position
- length of motor vs length of engine bay
you will have to put in a hilux diff or similar as you will break the ke10 diff the moment it comes on boost for the 1st time
you will also have to do brakes
unless you did most of the work yourself i would put aside 10k
faulksy
Re: 13BT in KE10 Tue, 12 October 2004 08:05 Go to previous messageGo to next message
bassy wrote on Tue, 12 October 2004 16:03
is it a white one? i know there is a white one in adelaide with a rota in it. wasnt sure what type of rota it was
pro_ke
adelaide
Re: 13BT in KE10 Tue, 12 October 2004 08:26 Go to previous messageGo to next message
12a in the white one
looks like a very tight squeeze
Re: 13BT in KE10 Tue, 12 October 2004 08:52 Go to previous messageGo to next message
i hope this is not for road use Wink
rke_011
adelaide
Re: 13BT in KE10 Sat, 19 March 2005 10:43 Go to previous messageGo to next message
i got the white one in adelaide with 12a in it. it is a tight squeez and will be expensive and hard sourcing brakes for it..
i have hit that problem now, coz im going 12at and dont want 4 wheel drums.. hope you do a 13bt and can give ME some advice Smile
its a learning experience.
Smile
styler
Re: 13BT in KE10 Sat, 19 March 2005 22:54 Go to previous message
yeah i take it this is for a track / rally car? cos i highly doubt you will get it registered.
Previous Topic:Boost Control install
Next Topic:help work shop manual
Current Time: Sat Oct 17 22:33:16 UTC 2026
Total time taken to generate the page: 0.0054681301116943 seconds
