Toymods » Tech & Conversions » ke70 diff to fit ke55, possible?
cwhelan
Adelaide, Semaphore
ke70 diff to fit ke55, possible? Tue, 12 October 2004 07:52 Go to next message
I have a ke70 sedan sitting in the shed just waiting to donate parts to my ke55. I am going to use the 5 spd gearbox and take the 4k motor out as a spare to work on. I noticed just today that the diff on the ke70 uses a torsion bar, helical spring and anti sway bar, where as the ke50 has leaf springs. Is it a better idea just to leave the original ke50 diff in place and just turn the leaf springs over to lower it. This isn't entirely the only reason for looking AT THE POSSIBLE SWAP..
The diff on the ke70 looks like it is a bit stronger, as the tubes covering the half shafts look thicker on the ke70. The only thing that I have also noticed is that the springs on the ke70 have a place for mounting just above the inside arches, whereas the ke55 doesn't have a place to put helical springs.
Therefore, my question is... Can I use the ke70 diff on the ke55 coupe and still use my leaf springs. If none of this seems like a good idea, then what is worth keeping from the ke70 to use on the ke55? The rest of the car will be up for grabs once I have anything worth keeping for the ke55. The doors, bonnet, boot, front right quarter panel are straight as a whistle. everything else is fairly good on the car also. Any help would be much appreciated. Are the brakes on the ke70 better than what is on my 79 ke55? I really must get this project underway then get the spare car gone to someone who will need the parts on the ke70......
cwhelan
Adelaide, Semaphore
Re: ke70 diff to fit ke55, possible? Thu, 14 October 2004 00:16 Go to previous messageGo to next message
Any takers on these questions? Any advice would be much apreciated Very Happy
alex_ta22
Newcastle, Hunter Valley
Re: ke70 diff to fit ke55, possible? Thu, 14 October 2004 08:16 Go to previous messageGo to next message
Plain and Simple, ke70 diffs are shit and prices to weld the KE55 mounts to it are expensive. Theres no point. Probably the only thing worth keeping from the KE70 for the KE55 is the 4K.
ChuckLandwehr
Re: ke70 diff to fit ke55, possible? Thu, 14 October 2004 08:22 Go to previous message
As above! and I am sure that the track,(distance between wheels) is quite a bit wider in the KE70 than the KE55. This alone would increase expenseto modify!
regards Chuck.
Previous Topic:ke30 4k exhaust
Next Topic:quick q does jza70 a340e bolt into jzz30?
Current Time: Fri Oct 23 07:50:18 UTC 2026
Total time taken to generate the page: 0.0068600177764893 seconds
