Toymods » Tech & Conversions » celica t50 gearbox?
Big T
celica t50 gearbox? Tue, 12 October 2004 10:15 Go to next message
does anyone know if a celica t50 is exactly the same as an ae86 t50. is it a straight hook up to a 4age or 4ac or does it require extensive modding? thanks.
eddie
gearb0x
Re: celica t50 gearbox? Tue, 12 October 2004 10:23 Go to previous messageGo to next message
short answer, no
longer answer, search
pheonix83
Devonport Tasmania
no they are not.
you need either an ae86, or ae71 t50.
what u can do is if u have a fcked ae86 t50 is chase down a t18 t50 and change over the bellhousings and a couple of things.
Sprinter-Saurus
Re: celica t50 gearbox? Tue, 12 October 2004 10:27 Go to previous messageGo to next message
Celica T-50 is a split-case gearbox as far as i know, Sprinter T-50 isnt. Smile
chris philpott
hobart
Re: celica t50 gearbox? Tue, 12 October 2004 12:07 Go to previous messageGo to next message
Celica T50 - 20 spline input & output shaft, forward shifter position & bellhousing to suit T series engine.
T18 T50 - 20 spline input & output shafts, rear shifter position & bellhousing to suit T series engine.
Spinter T50 - 22 spline input & output shafts, rear shifter position & bellhousing to suit A series engine.
This info is how I understand it to be, I may be corrected.
Cheers Chris Smile
demuire
Ipswich
Re: celica t50 gearbox? Tue, 12 October 2004 22:18 Go to previous messageGo to next message
Chris: I think that is correct, except I think all of them have the same input shaft, just the late model T50 (AE86) has a different output spline.
chris philpott
hobart
Re: celica t50 gearbox? Wed, 13 October 2004 00:46 Go to previous messageGo to next message
I am currently changing boxes at the moment and the input on the Ae86 is definitly 22 spline aswell.
Cheers Chris
demuire
Ipswich
Re: celica t50 gearbox? Wed, 13 October 2004 01:11 Go to previous messageGo to next message
I'm guessing that would mean that the early one is also 22 spline on the input shaft?
I've just swapped my Celica T50 for an AE86 T50 (onto a 16V 4AGE), and both bolted in (with the Celica T50 obviously requiring a different bellhousing), I only had to change the tailshaft...
EMP-2TG
Carlingford, Sydney
Re: celica t50 gearbox? Wed, 13 October 2004 01:30 Go to previous message
they all run the same input spline as far as i know
Previous Topic:HELP! PLEASE - URGENT! - FIXED!
Next Topic:2tgeu in ke 30 questions
Current Time: Fri Nov 20 14:45:02 UTC 2026
Total time taken to generate the page: 0.0051920413970947 seconds
