Toymods » Tech & Conversions » loss of boost after installation of intercooler
nik3t
perth
loss of boost after installation of intercooler Tue, 12 October 2004 10:52 Go to next message
hi guys
my 3t finally got a front mount cooler installed...
just that it feels like my car has dropped boost....was at 13psi and now it stuggling to get to 10 psi... dont see any leaks????????
nik
ae95
Re: loss of boost after installation of intercooler Tue, 12 October 2004 11:00 Go to previous messageGo to next message
intercooler pressure drop
Adam_Rolla
Sydney, NSW
Re: loss of boost after installation of intercooler Tue, 12 October 2004 11:07 Go to previous messageGo to next message
i agree, pressure drop
m8 of mine suffered the same.. but didnt realise till 6 months later when we commented on it Laughing
shinybluesteel
melbourne
Re: loss of boost after installation of intercooler Tue, 12 October 2004 11:16 Go to previous messageGo to next message
where is your boost gauge reading from, before intercooler or after? not that it should make much difference.
BlackSupra
Re: loss of boost after installation of intercooler Tue, 12 October 2004 11:58 Go to previous messageGo to next message
your car will be making more power on less boost.....
PSI is not the be all and end all
indian
south east - melbourne
Re: loss of boost after installation of intercooler Tue, 12 October 2004 22:52 Go to previous messageGo to next message
would the pressure drop be more if the intercooler was too big ., maybe u friend got a too big an intercooler
RWDboy
Re: loss of boost after installation of intercooler Wed, 13 October 2004 03:34 Go to previous messageGo to next message
I think if you take a look at the ideal gas formulae (which are actually kinda stupid because no gas follows those formulae word for word) you'll realise that you are still getting the same amount of air into the engine, and it's running cooler as well, which means you can get better overall performance.
Corona RT142
Campbelltown
Re: loss of boost after installation of intercooler Wed, 13 October 2004 04:19 Go to previous messageGo to next message
yes because the air is no colder it takes up less space thus exrting less pressure
Skip
Re: loss of boost after installation of intercooler Wed, 13 October 2004 04:26 Go to previous messageGo to next message
If the waste gate actuator is getting it's pressure signal from the turbo side of the intercooler, shouldnt you be able to get a bit more boost be simply plumbing the actuator line into the manifold?
79rollaboy
NSW Engadine
Re: loss of boost after installation of intercooler Wed, 13 October 2004 05:11 Go to previous messageGo to next message
In any application... you want the most power from the lowest pressure possible...
EG making 250hp off 10psi is far better than 250hp off 16psi... it's much more reliable to run lower boost...
Re: loss of boost after installation of intercooler Wed, 13 October 2004 05:20 Go to previous messageGo to next message
Skip wrote on Wed, 13 October 2004 14:26
bloody good idea Smile. not being a turbo owner, hadn't 'thunk' this..
HyDrA
Adelaide, SA
Re: loss of boost after installation of intercooler Wed, 13 October 2004 05:23 Go to previous messageGo to next message
Skip, it's a good idea, i've seen it done before Smile It also keeps the wastegate(s) closed for longer, thus bringing boost on quicker Wink
indian
Re: loss of boost after installation of intercooler Wed, 13 October 2004 05:51 Go to previous messageGo to next message
wouldnt that idea result in massive boost spikes tough , cause of the long hose needed to be run from the manifold to the turbo wastegates
how much in boost increase are we expecting
HyDrA
Adelaide, SA
Re: loss of boost after installation of intercooler Wed, 13 October 2004 06:00 Go to previous messageGo to next message
Not much of an increase, the increase will depend mostly on the pressure loss from the intercooler... it all evens out in the end.
Just get a boost gauge and keep an eye on the pressure Razz I don't see it spiking much/at all.
indian
Re: loss of boost after installation of intercooler Wed, 13 October 2004 06:07 Go to previous messageGo to next message
what hapens to the turbo ends then( where the pressure hose starts from) will runnin a hose from one opening to the other seal them
might try it when i get some time the 1g-gte also has a spare nipple to connect a vaccum source , lolllllll that helps
HyDrA
Adelaide, SA
Re: loss of boost after installation of intercooler Wed, 13 October 2004 06:14 Go to previous messageGo to next message
Just get a small length of hose, even the standard bit of hose coming from the turbos, and plug it up with something. Easy.
You'll want to get the new source of pressure from that L shaped pipe that bolts up to the throttle body. On the bend, there is a small hose which has a plug in it. You could find a suitable brass connector, knock out the plug, tap a thread and then attach a hose to this. Use a Y splitter and run one hose to each wastegate.
Of course, you could also adapt this idea to run higher boost pressure, as well as controlling how fast the boost comes on.
ke382TG
Re: loss of boost after installation of intercooler Wed, 13 October 2004 06:15 Go to previous messageGo to next message
I have run the wastegate actuator line from the inlet side of the intercooler and it resulted in unstable boost control and massive boost spikes (spiking of up to 7 psi over the preset level of 18psi). Different results may be found on another car though so no harm in giving it a try.....
Note: my turbo builds boost very rapidly and the slight delay that the above setup caused made for some big boost spikes, which was great if you just wanted to break traction and wheelspin everywhere, but was not great for trying to drive quick.
My current setup runs the wastegate actuator line from the first section of pipe after the turbo compressor housing (50mm post compressor housing) it is a super short line and it holds perfectly stable boost levels (on my high and low settings) and at 20 psi will only spike 1.5 psi (I can setup for no spike at all but for nice rapid boost response on my high boost setting I have it setup for a slight spike Very Happy ). I like 20psi at under 3000rpm for some quick acceleration Very Happy
Experiment with your setup to get the performance and characteristics that YOU are happy with. But be careful, don't blow up your engine!
[Updated on: Wed, 13 October 2004 06:19]
Skip
Re: loss of boost after installation of intercooler Wed, 13 October 2004 08:23 Go to previous messageGo to next message
indian wrote on Wed, 13 October 2004 14:07
Why would you bother? just buy some bungs to put over the spigots from your local autoparts store!
ke382TG: Did you mean you ran the actuator line from the outlet of your intercooler?
Skip
Re: loss of boost after installation of intercooler Wed, 13 October 2004 08:25 Go to previous messageGo to next message
BTW nik3t, what intercooler are you running, 3psi drop at only around 13psi sounds excessive?
Re: loss of boost after installation of intercooler Wed, 13 October 2004 10:42 Go to previous messageGo to next message
Sounds like a Mk3 Supra intercooler to me! Smile
EMP-2TG
Carlingford, Sydney
Re: loss of boost after installation of intercooler Wed, 13 October 2004 11:01 Go to previous messageGo to next message
remove the rag from the intercooler?
ke382TG
Re: loss of boost after installation of intercooler Wed, 13 October 2004 23:21 Go to previous messageGo to next message
Sorry that I didn't explain it clearly (I always do that), the waste gate actuator line was plumbed into the inlet manifold, but not any more as I explained a little later in my text.
3psi drop across the core at 13psi is a bit excessive.
[Updated on: Wed, 13 October 2004 23:21]
Bugman
Re: loss of boost after installation of intercooler Wed, 13 October 2004 23:32 Go to previous messageGo to next message
Umm.. dont plumb it into the manifold. plub it as close to the throttle body as possible but not after it.
other wise. you snap the throttle closed. manifold goes to vacum and closes wastegates. if you have been on boost your turbos are already spinning very quickly. then with the sudne closure of the wastegate you will result in a spike in boost pressure in the inlet piping, not the manifold as it's closed off and in a vacum.
ofcourse coupled with a blow off valve this may result in more PSSSCCHH for your $.
ke382TG
Re: loss of boost after installation of intercooler Wed, 13 October 2004 23:47 Go to previous messageGo to next message
Dead right!!
Even fitting just before the throttle body didn't make any significant difference in my case. The real benefits were made when it was plumbed in as close to the compressor housing as possible Very Happy
Hence my conclusion for my particular situation was that it was the length of the line that made the biggest difference (the shorter the better). Many factory setups have the wastegate actuator line plumbed into the compressor housing itself, for a very short line.
Some people like a big boost spike for some oomph between gears (I am not one of them) each to their own though.
[Updated on: Wed, 13 October 2004 23:49]
10sec_rx7
Syndey
Re: loss of boost after installation of intercooler Thu, 14 October 2004 01:00 Go to previous messageGo to next message
Bugman wrote on Thu, 14 October 2004 09:32
do you realise what you just said makes no sence at all???
when you close the throttle exhasut gas stops, when the exhuast gas stops the turbo isnt being driven any more weather the wastegate is open or the wastegate is closed.
hook up the waste gate where you can have the shortest lines possible,
im guessing the cooler is either a supra style one or one of these cheap shitty hybrids ebay jobs, if it is a hybrid check for air leaks as it is quite common for them to leak...
indian
Re: loss of boost after installation of intercooler Thu, 14 October 2004 01:29 Go to previous messageGo to next message
god damn so the 1g-gte stock intercooler is no go zone u guys reckon
and yes the longer the pressure line the bigger the spike as i mentioned before so best bet is to leave it factory cause its a small piece of hose in most cases and doesnt spike at all
im thibking of getting an intercooler soon
what do u guys reckon of this cooler for a gz20 soarer
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&a mp;category=32624&item=2494104827&rd=1
ke382TG
Re: loss of boost after installation of intercooler Thu, 14 October 2004 01:39 Go to previous messageGo to next message
Someones got there thinking cap on!! Hehehe I am too tired to think about things in such a logical process at the moment Very Happy (yes i know it is the middle of the day but I get up early).
The reason that I tried running the line pre and post throttle body back in the day was because I thought that the vacuum acting on the actuator may have been contributing to the delay thus causing the spike (it was only a thought though that going from vac to boost versus atmospheric pressure to boost was causing an ever so slight delay that contributed to boost spikes, but as i pointed out above fitting just pre or post throttle made SFA difference). In the end as said above it all came down the the length of the line, short is best.
I am going to shut my trap now Very Happy I need a sleep.
10sec_rx7
Syndey
Re: loss of boost after installation of intercooler Thu, 14 October 2004 01:50 Go to previous messageGo to next message
short and hard lines, like good quality vacuum hose (not expansive silicon hose as it swells), braided hoses or even solid pipe!, this will increase the accuracy of a bleed valve as well and ensuring the same boost each time,
on external gates you often have to run larger lines as well,
Sleep is a good thing Smile
nik3t
perth
Re: loss of boost after installation of intercooler Thu, 14 October 2004 11:57 Go to previous message
Thanks for feedback
im running a ford cosworth bar and plate cooler... not big at all...
ive noticed last night my temps were around 28 on full boost...a drop of 50 degrees b4 cooler...
running better but im sure its dropped boost... mates tellin me to put a boost controller and wind it up...sounds good but i mite take it to the dyno guy and see wtf is happenin...
it never ends!!!!!
Previous Topic:Recommended Mechanic for 20V tune in Bris? (standard ECU)
Next Topic:1g cutting out at 4000rpm
Current Time: Fri Oct 23 10:10:36 UTC 2026
Total time taken to generate the page: 0.0084190368652344 seconds
