Toymods » Tech & Conversions » AE86 Handling Mods
Necros
AE86 Handling Mods Mon, 30 September 2002 03:23 Go to next message
Hey Guys,
Where is the best place to start upgrading/modifying the suspension in a AE86 Sprinter? Springs, Shocks, Swaybars Etc?
Youngy
Eskilstuna, Sweden
Re: AE86 Handling Mods Mon, 30 September 2002 07:40 Go to previous messageGo to next message
If you can't afford to do everything at once, I would do this.
1. Sway bars
2. Urathane bushes in all the right places
3. Shocks and springs at the same time, doing them seperately is often a step backwards in the handling arena
I'm sure there will be just as many opinions as there are options
Sprinter
Re: AE86 Handling Mods Tue, 01 October 2002 11:56 Go to previous messageGo to next message
I would add one other part to step 3 if you fit lowered springs. Make sure you get some roll centre adjusters (Whiteline have them). They help immensely after you have lowered the car.
Otherwise follows the steps Youngy listed.
Denis
AE86 (with King springs, KYB gas and 30mm RCA's)
5KinKP60
Finland
Re: AE86 Handling Mods Tue, 01 October 2002 12:52 Go to previous messageGo to next message
Sprinter's addition is valid.
I urge not to lower rear axle tremendeously. Keep long trailing arms parallel to ground level. Period.
If rear must be lowered a lot - install brackets onto axle which relocate trailing arm fixing points. That will fix 'em to be parallel to ground. There are companies in Japan making these brackets for AE86.
With speed bumps and all, why not just stiffen the suspension and maintain factory original suspension height?
This way all suspension arm angles are correct, and car behaves ideally. It may look like a dog since it's sitting so high but who cares.
-A.
Re: AE86 Handling Mods Tue, 01 October 2002 13:39 Go to previous messageGo to next message
and then at least it makes a good rally car Shocked Long as you don't go spending money on the paint, dirt roads rock!
5KinKP60
Finland
Re: AE86 Handling Mods Tue, 01 October 2002 20:52 Go to previous messageGo to next message
Dirt roads rock 'eh?
http://www.ralli.net/kuvat/2002/kives02_11.jpg
http://www.ralli.net/kuvat/2001/dna01_17.JPG
http://www.ralli.net/kuvat/2001/dna01_10.JPG
http://www.ralli.net/kuvat/2002/kiuru02_3.jpg
http://www.ralli.net/kuvat/2002/kiuru02_7.jpg
http://www.ralli.net/kuvat/2002/isralli02_18.jpg
http://www.ralli.net/kuvat/2002/isralli02_7.jpg
http://www.ralli.net/kuvat/2002/arctic02_12.jpg
http://www.ralli.net/kuvat/2002/lem02_20.jpg
http://www.ralli.net/kuvat/2002/lem02_11.jpg
ae86trueno
Re: AE86 Handling Mods Tue, 01 October 2002 23:07 Go to previous messageGo to next message
i think i was born in the wrong country Crying or Very Sad
http://us.f1.yahoofs.com/users/fdc6ad13/bc/My+Photos/oran1.jpg?bcRIcw9AKVA73D1l
http://us.f1.yahoofs.com/users/fdc6ad13/bc/My+Photos/oran2.jpg?bcRIcw9AtLh.8972
Ben
AE86 Trueno 4AGE
Necros
Re: AE86 Handling Mods Wed, 02 October 2002 00:14 Go to previous messageGo to next message
On the second day I bought my AE86 I took the oportunity to go down a 12km one way rally track.... Tight and windy Smile I went around twice heheh
The handling of the sprinter might have a little bit to be desired on bitchumen but on dirt they are fantastic stock Smile Can wait till I do some mods to see how she goes!!!
Re: AE86 Handling Mods Wed, 02 October 2002 01:22 Go to previous messageGo to next message
Whats with every one of those being coupes?
ae86trueno
Re: AE86 Handling Mods Wed, 02 October 2002 01:49 Go to previous messageGo to next message
Just lucky i guess ???
Lower CG ?? less weight behind the rear wheels ??
Ben
AE86 Trueno 4AGE
Re: AE86 Handling Mods Wed, 02 October 2002 02:15 Go to previous messageGo to next message
I'd say its probably the same reason the TA63's were all coupe's, because the chassis was stiffer.
Youngy
Eskilstuna, Sweden
Re: AE86 Handling Mods Wed, 02 October 2002 12:18 Go to previous messageGo to next message
Man, no wonder so many gun drivers come from Finland!
jazae86
Re: AE86 Handling Mods Thu, 03 October 2002 14:39 Go to previous messageGo to next message
If money is no object here's my sus set up:
Strut tops
Short stroke coilovers
RCA's as tall as the car is lowered
Tokico HTS dampers front and rear
24mm adj sway bar front. -learn from TRD (20 and 22mm only)
18mm rear
250lb front, 200rear springs
front and rear strut brace (both tri-angulated)
All new bush's.
a little camber for the rear as well (read Bill's site Smile )
You may also want some longer control arms, but not longer than steering arms can go.
that's about is.
Change from 3K......yeah right, if that covers it Wink
Jaz
And the AE86 coupe has alot more structure to it over the rear wheels. Definantly stiffer.
LiL_MiC
Melb
Re: AE86 Handling Mods Thu, 03 October 2002 17:09 Go to previous message
according to some discussions in another forum .. [i think it was club4ag], not only are the coupe's stiffer, but also lighter! something like the glass window on the back of hatches make hatches heavier!
Previous Topic:Newbie
Next Topic:Engine conversion - should I convert to manual at the same time?
Current Time: Sun Oct 18 01:16:02 UTC 2026
Total time taken to generate the page: 0.0055310726165771 seconds
