Toymods » Tech & Conversions » How to fix fuel sender ?
Les
icon5.gif  How to fix fuel sender ? Tue, 12 October 2004 16:23 Go to next message
u know that thing that tells you how much fuel u have ... well mine is stuffed ... full tank on the gauge is apparently a full tank ...
we think it is the sender ... how to fix ??
has anyone had the same problem ? how did u fix it ? Embarassed
jackel
Re: How to fix fuel sender ? Tue, 12 October 2004 16:27 Go to previous messageGo to next message
have you pulled out the fuel sender? it could be stuck?
YelloRolla
On your mum!
Re: How to fix fuel sender ? Tue, 12 October 2004 21:30 Go to previous messageGo to next message
Les wrote on Wed, 13 October 2004 02:23
Full guage = full tank? Seems as though that is what it is supposed to read.
If fuel sender is stuffed simply remove and replace with another!
Les
Re: How to fix fuel sender ? Tue, 12 October 2004 23:27 Go to previous messageGo to next message
YelloRolla wrote on Wed, 13 October 2004 07:30
HAHAH the gauge reads HALF TANK when it is actually FULL thanks for picking that up !
wagonist
Toymods Club Treasurer
Re: How to fix fuel sender ? Wed, 13 October 2004 02:23 Go to previous messageGo to next message
Generally this is the procedure for fixing the sender:
1. pull existing one out of fuel tank
2. take it to a wrecker to match it to a replacement
3. pay money...
4. install replacement
5. find nearest trash recepticle for stuff one
6. don't run of fuel any more...
Les
Re: How to fix fuel sender ? Wed, 13 October 2004 02:34 Go to previous messageGo to next message
how do u know it is stuffed is my question
wagonist
Re: How to fix fuel sender ? Wed, 13 October 2004 02:43 Go to previous messageGo to next message
It should operate on a float with a pivot.
Take it out of the tank but leave it wired up.
Have someone sit in the front watching the fuel guage as you swivel the float (obviously with the ignition in the "ON" position).
may take some time for the guage to react, they have dampeners on them to stop the guage fluctuating wildly as the fuel sloshes around in the tank.
EvilJack
Sutho/Hills NSW
Re: How to fix fuel sender ? Wed, 13 October 2004 08:50 Go to previous messageGo to next message
there not exactly expensive
grab one from a wreckers wack it in, if it works then your original one is stuffed Smile
Les
Re: How to fix fuel sender ? Wed, 13 October 2004 12:04 Go to previous messageGo to next message
will flog one from the wrecker to try
jackel
Re: How to fix fuel sender ? Wed, 13 October 2004 12:31 Go to previous message
why not just take it out and move it back and forward while the ignitor is turned on so you can see if it is broken or not. No point buying another one if it ain't broken.
Just make sure you cover the opening of the tank incase a spark or something occurs Confused
Previous Topic:EFI Design - 4cyl GE L-Jetronic (I suck!)
Next Topic:After maket power antenna replacement on RA60?
Current Time: Fri Nov 20 06:50:51 UTC 2026
Total time taken to generate the page: 0.026134014129639 seconds
