Toymods » Tech & Conversions » 2tgeu in ke 30 questions
dave_ke30
sydney, the shire
2tgeu in ke 30 questions Tue, 12 October 2004 22:30 Go to next message
with the $$ flow on the rise, its time to upgrade my ke30 from a 3k to most likely a 2tgeu... i have a few questions on the subject so any help would be greatly appreciated...
how much $$ do the front cuts go for a 2tgeu?
or do i even need the fron cut should i just buy the engine and box??
proberly runing a t50 g/box what will need to be done to the tail shaft to fit the sucker in?
would a suspension upgrade be necessary or can i get away with stock suspension with lowered / hardened springs?
any help with these issues would be great,thanks
dave.
pheonix83
Devonport Tasmania
Re: 2tgeu in ke 30 questions Tue, 12 October 2004 22:33 Go to previous messageGo to next message
easiesy way is use a donor ta22 celica.
that way u take the engine gearbox, i think the tailshaft, and the clutch cylinder.
just get some engine mounts modified and your off
EMP-2TG
Carlingford, Sydney
Re: 2tgeu in ke 30 questions Wed, 13 October 2004 00:52 Go to previous message
all you need is a motor, box and engine mounts
the stock (manual) tailshaft bolts up, and all you need are engine mounts, the stock gearbox mount bolts the the box in the rear position (there are 2 places under the car to bolt it, use there rear mounting holes)
you will also need to add a clutch master cylinder and modify the clutch pedal, mine runs half TA22 pedal/half KE30 pedal
there are dimples in the firewall already where you have to drill to mount the clutch MC...
btw ive got a set of custom 2TG into ke30 mounts for sale Razz
oh and a couple of T50's
Previous Topic:celica t50 gearbox?
Next Topic:Cleaning & reoiling an HKS air filter?
Current Time: Fri Nov 20 15:02:42 UTC 2026
Total time taken to generate the page: 0.010948181152344 seconds
