Toymods » Tech & Conversions » Turbo GZE question....
4A-GTE
Rockhampton, Queensland
Turbo GZE question.... Wed, 13 October 2004 01:00 Go to next message
Hello,
i am half way through the engine conversion and have come across a hurdle in my work. A few people have told me different things and i am not sure what to do. I am replacing the factory supercharger with a turbo.
My turbo is water and oil cooled, the oil lines i have hooked up already, but which is the best place to run the water feed and return lines?
Daniel
4A-GTE
Re: Turbo GZE question.... Wed, 13 October 2004 01:39 Go to previous messageGo to next message
bump
CrAiGzEE
south of the big smoke
Re: Turbo GZE question.... Wed, 13 October 2004 01:49 Go to previous messageGo to next message
heater lines
onemxracer
perth
Re: Turbo GZE question.... Wed, 13 October 2004 09:17 Go to previous messageGo to next message
prob have one b4 the water pump n one after
TA22-3SGTE
MACKAY
Re: Turbo GZE question.... Wed, 13 October 2004 09:38 Go to previous messageGo to next message
T into each of the water lines going to the bottom of the throttle body .
Trevor
4A-GTE
Re: Turbo GZE question.... Wed, 13 October 2004 10:26 Go to previous messageGo to next message
so a T section into each of the throttle bodies water lines eh? i might give that a go i think. As long as the turbo gets a flow of water i guess it should not matter too much, if all else fails i guess the best option is to go with T sections in the heater hose lines??? but aren't they meant to be HOT??
the throttle bodie water lines sound better to me i believe!
Daniel
juzzo84
Hornsby, N.S.W
Re: Turbo GZE question.... Wed, 13 October 2004 10:31 Go to previous messageGo to next message
where possible, try to bridge into somewhere where the water has only just left the radiator, that way the turbo will recieve the coolest possible water flow!!
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: Turbo GZE question.... Wed, 13 October 2004 10:38 Go to previous messageGo to next message
depending if you are north-south or east-west...
north-south: just T into the heatercore lines, hose sizes are appropriate usually.
east-west: id prolly guess TB is easier to tap into? i dont really care...
keep in mind, you dont have to hook up the coolant lines to the turbo. but i would recommend you do anyway.
where you take the coolant from shouldn't make bugger all difference, when the coolant is hot, its hot everywhere... go for flow.
cheers,
James
feral4mr2
Bundaberg, Qld.
Re: Turbo GZE question.... Wed, 13 October 2004 21:04 Go to previous messageGo to next message
like most of the other guys said, i tee'd into the heater lines just like the HKS turbo conversion kits that used to be available for AW11's.
something bothers me about running extra heated up coolant through the TB.
4A-GTE
Re: Turbo GZE question.... Thu, 14 October 2004 00:42 Go to previous message
thanks for the help guys, most appreciative!
Daniel
Previous Topic:Few questions, Reasonably modified 7M-GTE Supra
Next Topic:trim codes explained please
Current Time: Wed Oct 14 04:38:06 UTC 2026
Total time taken to generate the page: 0.094882965087891 seconds
