Toymods » Tech & Conversions » Mixture screw on 4A-C
WHITCHY
Castle Hill
Mixture screw on 4A-C Wed, 13 October 2004 01:43 Go to next message
Can someone please help me out with this, with the mixture screw on the 4A-C, do you screw it to the left to make it run richer, and the right to make it run leaner? or is it the other way around?
Thanks for any help.
-Whitchy-
Bobski
Re: Mixture screw on 4A-C Wed, 13 October 2004 03:10 Go to previous messageGo to next message
pretty sure its counterclockwise for richer clockwise for leaner, or....unscrew for richer screw in for leaner....or.....unscrew motor....screw in 4age Very Happy
good luck dood
Adam
jesseT18
Castle Hill, Sydney
Re: Mixture screw on 4A-C Wed, 13 October 2004 08:54 Go to previous messageGo to next message
wind it like 3 turns one way then smell ur exhuast, if u went the rich way ull get a nice wiff off petty i think
don't get addicted to the fumes though....
M.W.P.
Rocky Mountains, Canada
Re: Mixture screw on 4A-C Wed, 13 October 2004 11:12 Go to previous messageGo to next message
Unscrewing it (anti-clockwise) will make it richer.
Remeber though, its the idle mixture screw... it doesnt effect the whole RPM/throttle range.
brett_celicacoupe
townsville NQLD
Re: Mixture screw on 4A-C Wed, 13 October 2004 11:22 Go to previous messageGo to next message
its like a normal water tap....turn clockwise to restrict flow.
with motorbikes, the standard setting is all the way in and 1 + 1/2 turns out.
be careful to not screw it in to hard bcos the tip can get wedged in and snap off. not fun to remove No No No ....still havent figured out how to remove mine yet Mad (wasnt me either)
Bobski
Re: Mixture screw on 4A-C Wed, 13 October 2004 11:50 Go to previous messageGo to next message
lol i think the nr of turns will vary.....i think u should...wind all the way in...unwind 1.5-2.5 turns.....turn slowly with car running....the revs will go up/down..... when u find a place where they stop going up and start going down...or the opposite stop there....test drive
Adam
M.W.P.
Re: Mixture screw on 4A-C Wed, 13 October 2004 18:10 Go to previous message
The correct method:
Screw mixture screw out 5 turns from all the way in.
Set idle speed using acel stop screw.
Screw in mixture screw until RPM at idle drops by 50 to 100 RPM.
Previous Topic:20V ST - Turn distributor which way to advance ignition?
Next Topic:AFM Q
Current Time: Fri Nov 20 07:09:57 UTC 2026
Total time taken to generate the page: 0.082447052001953 seconds
