Toymods » General Car Talk » Sunroof leaks
tooch
Bulleen, Melbourne
icon8.gif  Sunroof leaks Wed, 13 October 2004 10:35 Go to next message
Bloody Melbourne weather! Mad
In the massive downpour all day today, my GT4's factory sunroof decided to leak. Quite a bit too, the roof liner was pretty wet! Dried it off now, what would be the likely cause of this? The seal looks to be in decent condition, maybe if I soften it up a bit with some vaseline or grease?
Just don't want this happening every time it rains here!
Jag7799
Re: Sunroof leaks Wed, 13 October 2004 11:20 Go to previous messageGo to next message
tooch wrote on Wed, 13 October 2004 20:35
thats strange... my 83 soarers one never had a problem with leaking
does the sunroof look like its been taken apart before?
theres a little metal part that sits inside the seal that is pressed to make it an exact seal.. without it, it would leak
also.. are u sure the mechanics of it are pulling it 100% shut?.. see if u can push it any more up/further
Arch
Re: Sunroof leaks Wed, 13 October 2004 11:59 Go to previous messageGo to next message
my factory sprinter sunroof saw some pretty heavy rain this season, not 1 bit of leak Smile
rust increased tho...
Jag7799
Re: Sunroof leaks Wed, 13 October 2004 12:12 Go to previous messageGo to next message
Arch wrote on Wed, 13 October 2004 21:59
my sunroof had very little rust in it for 20 y/o sunroof
all rust sanded out etc.. replaced with new metal and what not.. and then paint painted so thick, it aint never rusting again
tooch
Bulleen, Melbourne
Re: Sunroof leaks Wed, 13 October 2004 12:21 Go to previous messageGo to next message
Hmm all looks pretty legit from what I can tell. I was parked under a tree and it was raining like all fuck, and the car was soaked, so maybe it was just the sheer amount of water, and maybe it wasn't 100% closed....Not sure....I'll keep an eye on it, maybe take it to a sunroof place and just let them have a look cos I can't see anything wrong with it!
Jag7799
Re: Sunroof leaks Wed, 13 October 2004 12:29 Go to previous messageGo to next message
tooch wrote on Wed, 13 October 2004 22:21
unhook the cloth trim on the sunroof... close it ALL THE WAY.. and run a hose over it.. see where it leaks from
Spanktown
Inside a giant turbo (syd...
Re: Sunroof leaks Wed, 13 October 2004 12:58 Go to previous messageGo to next message
stuff vassy... get some "silicone lubricant" from any autoparts store and smear a bit over the seals... fixed my T-Top leaks
RobST162
Re: Sunroof leaks Wed, 13 October 2004 13:11 Go to previous messageGo to next message
tooch
does your sunroof have that little gutter that runs around inside it below the seal..
if so you may want to test your gutter outlets that run down the pillars of the car.. they can get blocked and can be cleaned with an air pressure hose.. or even a bit of wire
mk1sc
Re: Sunroof leaks Wed, 13 October 2004 15:14 Go to previous message
what rob said, leaves and crap can block drain holes and passages. if water cant drain down the car it will drain into thru the sunroof. just clean it out
Previous Topic:FRP PANELS FOR TA22 AND OTHERS IN VICTORIA MELBOURNE PLEASE READ!
Next Topic:116 soarer questions
Current Time: Mon Oct 19 06:04:35 UTC 2026
Total time taken to generate the page: 0.11333012580872 seconds
