Toymods » Tech & Conversions » 4age timing diag mode
4age timing diag mode Wed, 13 October 2004 23:22 Go to next message
Hey, I just wanted to confirm that you earth out the T pin on the ECU when you want to set the timing?
There is no diag plug wired up anymore.
Joel
leebroozlee
Re: 4age timing diag mode Thu, 14 October 2004 00:15 Go to previous messageGo to next message
usually T1 + E1 on the diag box so yeah probably
should hear the engine speed up a bit then slow down when you do it...if it doesn't short circuit something Shocked
-paul
Re: 4age timing diag mode Thu, 14 October 2004 05:25 Go to previous messageGo to next message
i have had problems getting my 4age into timing diag mode whilst its running, so i turn the car off, and then start it up with the pin shorted. YOu can tell when its in diag mode as the timing stays static rather than moving around.
When i have set my timing, i leave the T pin shorted and reef it out with the engine running and double check that the timing has modified itself Smile
Works everytime.
Remember = T for timing.
Re: 4age timing diag mode Thu, 14 October 2004 05:38 Go to previous messageGo to next message
Thanks all much appriciated Smile
t = timing.. I think i can remember that!
IRA11Y
Club Member
Re: 4age timing diag mode Fri, 15 October 2004 09:07 Go to previous messageGo to next message
T1 and E1 the car has to have the ignition turned off when you bridge so that the ecu fires into diagnosis mode when it recieves power up then you can check the timing.
FKN16V
NSW, East Coast
Re: 4age timing diag mode Fri, 15 October 2004 22:56 Go to previous messageGo to next message
IRA11Y wrote on Fri, 15 October 2004 19:07
"Short the terminals before starting" would it matter if i can do it anytime as long as the terminlas are shorted, when i short the terminals the motor dies of a little anf the timing changes, thats right isnt it, and then you just change the timing as required.
Steve
leebroozlee
Re: 4age timing diag mode Sat, 16 October 2004 10:33 Go to previous message
that's how i do my rolla, and celica too..seems to be right.
Previous Topic:will a AE86 bodykit bumper fit on an AE82??
Next Topic:Air con and idle
Current Time: Fri Nov 20 17:38:07 UTC 2026
Total time taken to generate the page: 0.004892110824585 seconds
